Weber Carb Linkage, Yes I checked the Wikki
From PHILLY USA
Driving me nuts,
I get the carb all installed and the linkage just seems strange. Do I actually disassemble the weber to put my linkage on? There are already bits on it. And it came with a throttle switch but I cant figure out if I am suppose to use this. Also I got a throttle cable guide for it that goes on the side of the carb.
Also the bung hole for the hose to go to the breather is that suppose to be on the front right corner of the air filter? That seems like a bad design to me.
See pics.
Posted on: 2008/11/8 23:31
Re: Weber Carb Linkage, Yes I checked the Wikki
From Tamworth , NSW
Posted on: 2008/11/8 23:34
From Tamworth , NSW
it looks to me that you wanna remove that silver doover and replace with the round thingo(in the last pic) and then fix it onto the shaft with one of those nuts a nut
make sense?
im no expert on these carbys by the way.
Posted on: 2008/11/8 23:37
From Charlevoix, MI USA
Datsunitus-
If you want, I can send you pics on how I have mine installed. Yes it can be a little confusing,but you have everything in the palm of you hand from the photos below.
Posted on: 2008/11/9 2:32
"from the land of the graceless bumper"
'78 B210GX BREwannabe'
From PHILLY USA
Hello,
Please do Huge2na@gmail.com
Thanks in advance
LONGBROW wrote:
Datsunitus-
Posted on: 2008/11/9 2:36
Wilco will have out to you tommorrow.
Posted on: 2008/11/9 2:41
Items sent
Posted on: 2008/11/9 4:32
From PHILLY USA
LONGBROW wrote:
Items sent
Thanks to your help it is all done.
Here is an interesting way to hook up the throttle return spring. I used a Shisk Kabob skewer. Looks pretty lol
Posted on: 2008/11/11 5:02
