Re: Don't be fooled by the GX title!!
From hastings,vic
vac advance should cum from a hole in carby that lines up with butterfly just of idle( vac advance when cruz, low load only)
advance off manifold,vac advance at idle/ to mutch advance!
tommo
Posted on: 2008/11/11 9:55
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From Adelaide, Australia
Thats the one, the brass dick, best description ever.
Your economy will be bad because its not advancing enough through the revs without the vac advance.
Here a pic where the hose goes.
Posted on: 2008/11/11 9:57
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sydney
The port for vuc advance is inline with the throttle plate. Remember that the butterfly is eliptical shape and not circular and when the throttle is closed the butterfly sits at an angle and not "square" to the bore The vucuum is only applied when the throttle plates moves off the closed position.
If yours is not hooked up yet Pepper, this could explain some of your engine problems you have been experiencing.
Posted on: 2008/11/11 9:58
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Darwin NT
if you dont have the vac advance connected it doesnt really do anything mines not connected webbers and dellortos dont have it
and i havent been running it for quite a while seems to be just fine
Posted on: 2008/11/11 10:01
current project 4x4 patrol...
From Tamworth , NSW
yeah benny, i didnt even see that port until just then, it was running a bit sluggy on the hiway today. hopefully its something as stupid as that after all the points-ig lead-dizzy cap gasket replacing ive been doing.
Posted on: 2008/11/11 10:05
if you dont have the vac advance connected it doesnt really do anything mines not connected webbers and dellortos dont have it and i havent been running it for quite a while seems to be just fine
Vacuum advance in standard distributors is worth about 10
Posted on: 2008/11/11 10:12
IPRA Build
From Sydney
Vucuum advance does heaps. Dont compare webers /dellortoes to SU /hitachies. The SU's type carb works solely on the vucuum created on the engine side of the throttle plate in order to operate. Webers and Dellortoes have the "accelerator pump circuit to counteract the rush of air when the throttle plates is opened.
Typically the static timing is advanced when Weber /dellortoes carbs are fitted..
Also if pepper has not blocked off the vacuum port on the front hitachi then that carb will see a vucumm leak. If the leak is present then the air rushing over the bridge, where the jet sits will be reduced. This condition will induce a lean mixture condition. The twin carbs will be out of balance also.
Posted on: 2008/11/11 10:13
1970 KB10 Coupe
S13 caliper b...
From Darwin NT
mines an elecy dizzy from something it wasnt connected when i got the car it was running really bad when i got it due to someone plugging in the spark plug leads in the wrong order ended up fixing it to the order it should be but then wouldnt run so did a full 180deg turn and the motor fired up beutifully and i left it like that till the rear carb #### itself now im losing fuel at the rate of about a litre a minute but i havent had the vac advance contected but still runs fine
Posted on: 2008/11/11 10:18
From Perth WA AUS
Whoops!
Datsun 1200 2Dr sedan.
From Sydney
As far as I can remember the difference between the std dizzy and a GX spec dizzy is the return springs on the mechanical advance. it was either, 1. the use of a single return spring from a A10 engine dizzy or 2. the use of only one return spring in an A12 dizzy. I will look it up and confirm..
Posted on: 2008/11/11 10:22
1970 KB10 Coupe
S13 caliper b...
« 1 2 3 (4) 5 »
