Will 1200gx carbs fit on a standard a12
From Bendigo
Will 1200gx carbs fit on a standard a12?
Im a bit cashed up at the moment and want to burn some into the motor. Im not too far off another car so assembling all the parts for a rebuild which will happen wit the new car. Just want to make sure they will fit?
Cheers Ed
Posted on: 2008/11/13 7:21
Re: Will 1200gx carbs fit on a standard a12
From South Africa, Bloemfontein
If your cylinder head has round intake ports and you are going to use a GX intake manifold, then No.
Posted on: 2008/11/13 7:37
1977 Datsun 1200GX
From Zimbabwe
Yes I agree you would need the GX head to make it work or get new intake manifold to suit your A12.
Posted on: 2008/11/13 7:46
You need to make sure that you ask the right question. To answer the question that you asked, the answer is NO.
The carbs will not fit onto a 1200 engine because the carbs bolt onto a manifold.
If you have a suitable Lynx twin SU manifold, then the carbs will fit to that, but will be spaced too far apart for the stock linkage to fit & work. [I tried it]
If you want to know if a 1200 GX 'induction' will fit a stock 1200 engine, then the answer is no.
If you have a GX head complete with induction & want to know if that will fit a stock 1200 block, then the answer is YES.
Posted on: 2008/11/13 14:56
Love your Datsun.
Treat it well.
if its a round port su manifold then will fit round piort head, oval port manifold will fit oval port head... easy to make a bodge linkage from threaded rod, lock nuts and some steel plate for the strikers onto the carbs.
Posted on: 2008/11/13 21:31
