GXU73- a new direction.
From Tamworth , NSW
now my ute is up and running, ive decided its gonna be time to use the quad bike carbys i have sitting in the shed.
the twin carbys and airbox will be removed.Open in new window
and using the inlet flange provided by tnpshow, and bike carbys supplied by frankthedolphintrainer
hopefully we will be seeing them on there soon.
i have a block which will get a bellyfull of new pistons and will use the gx head im already running on the car.
id like to hear from people who have tackled this and got it going and what i should look out for.
pics as i progress
Posted on: 2008/11/16 7:19
Re: GXU73- a new direction.
From newcastle, NSW
i wish you well in your new direction.
Are you selling the carbies by any chance?
Posted on: 2008/11/16 7:36
From Lethbridge, AB, Canada
Good luck! I wouldnt tackle that... but then again, most people are ALOT smarter than me.
Posted on: 2008/11/16 7:39
'73 Datsun 1200 Sedan Turbo A12
From Tamworth , NSW
cheers guys
steveo, nah, not going to sell em. slam, youll never know if you dont give it a go.
hopefully i can get a heads up on the pitfalls so i can avoid them.
Posted on: 2008/11/16 7:43
I have seen a few of these done around here & it's not a particularly difficult conversion, however, .......... you will have no ported vacuum for the distributor, so in highway cruise mode, you will be effectively running timing that is retarded from the optimal position.
Desirably you will interconnect the four runners with a smallish tube that runs parallel with the crank with a fitting for the PCV valve. The idea is to share the crankcase fumes between all the cylinders & this way you will have some vacuum to make it work.
If possible, hook up a fuel pressure guage to the fuel line for test purposes. When Aidens first engine was built it was found to run lean at full throttle & this was in part because the fuel being sucked in was more than the pump could maintain. When a second fuel delivery line, with a second pump was added, the pressure was maintained & things improved. A little jet drilling fixed the remainder of the problem.
So there you have it
PVC
Fuel pressure
Jet size
No ported vacuum.
Posted on: 2008/11/16 8:11
Love your Datsun.
Treat it well.
From Tamworth , NSW
thanks dodgeman, exactly what i wanted to hear.
do these particular carbys have to sit flat, or can i aim them downish kindof?
Posted on: 2008/11/16 8:20
From Wagga Wagga, NSW
I would also lie to know this however i would like to sit mine "upish" to clear my clutch master cylinder, after abit of visual research i have seen quaite a few pics with bike cars a wide variety of angles.
Jake
Posted on: 2008/11/16 8:28
From The garage, NZ
nice move. I too have a rack of bike carbs that will find their way onto one of my a series and more than likely into my ute.
What size are your carbs? There are quite a variety of sizes to choose from an i rekon our a series would benifit from the smaller end of the scale, on a road car anyway
Posted on: 2008/11/16 8:37
From Tamworth , NSW
mine are 34mm
Posted on: 2008/11/16 8:39
From Darwin NT
pepper i think i have a set of carbs the same as those sitting around somewhere... are they keihin?
Posted on: 2008/11/16 8:50
current project 4x4 patrol...
