Re: Problems getting after market seats in, HELP
From Wagga Wagga, NSW
thanks heaps for the pic. helps heaps. so you ran the flat bar facing front to back not left to right? and do you know the lenght of those bolts and spacer?
Posted on: 2008/11/18 9:30
Not too shy to talk
From Greece Athens
What i have done with my old seats? I put them away and got a pair of Honda CRX. They are not like Sparko,Momo,Recaro and other but they are good buckets...
Also i forgot to say that i kept my original seat bars.
Posted on: 2008/11/18 9:45
From hastings,vic
spaces about 30 mm,30x5mm plate 45mm bolt ,unbrakos, welded nut
tommo
Posted on: 2008/11/18 10:26
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From hastings,vic
plate might be bigger on driver seat, drivers seat closer to center of car, more albow room
Posted on: 2008/11/18 10:39
Not too shy to talk
Hi.I fitted Laser seats into my 120y. I just welded a plate of 2mm steel about 75mm square on to the bottom of the seats over the other bolt hole positions, drilled new holes so as to center the seat and used the original bolts with spring washers and ht nuts.
Used the original dato seat rails. Depending on the new seat and the dimensions involved you may be able to reuse some of the existing holes. I was going to get excited and weld the nuts onto the bottom of the 2mm plate before welding it to the seat but impatience got the better of me. If you do this be sure to make up a splatter gaurd (even thick cardboard might work) so as not to burn holes in your seat when welding (hindsight is a wonderful thing)
They work fine and it passed the blue slip.
Posted on: 2008/11/18 21:38
hey thanks for all the help fellas. got my seats in today. had a few problems, nothing some new smaller bolts couldnt fix. 30mm spacer are a bit big, i might change them one day. im short as and im squished in there.
Posted on: 2008/11/20 7:59
« 1 2 (3)
