Re: Car uses coolant but not water?
From Adelaide, Australia
Sorry its hard to have stuff come into your head, then write it out in some legible form.
Most of those premix bottles say to use distilled water, it has just been demineralised.
Posted on: 2008/11/18 9:33
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Bendigo
Yeah I think I'll just get the recovery bottle going. The point to me not using one was not because it didn't come with one just I couldn't be bothered. Thanks for the advice! Am so curious as to why this is happening though! It is Bmw coolant tht I use, dont see how that could be causing it though!
Cheers Ed
Posted on: 2008/11/18 9:38
From Melbourne, Oz
Distiled water has a higher boiling point and is les corosiv. so would be better than just tap water, but I think as sone as is get's impurities in it it's just plain water again I think, so you would need a bloody clean water system for it to do anything??
Posted on: 2008/11/18 9:59
"I hav achieved wood"
From Canberra, Australia
tried emptying the radiator and just using the premixed stuff?
Posted on: 2008/11/18 13:55
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
From gold coast QLD.
And back when Dinosaurs ruled the earth,a half a cup of Kerosine was added to the radiator tap water to lift the boiling point and as an anti corrosive agent.
You've had good advice from the guys,now go implement it and report back.
Posted on: 2008/11/18 22:01
From Melbourne, Australia
EWWWW premix!
Stay away from that stuff I make my cordial stronger than that stuff is mixed. Always mix your self!
Posted on: 2008/11/19 0:27
pre mix is good for testing the system before pouring $30 antifreeze/boil in there though, and thats it.
Posted on: 2008/11/19 0:32
When you put it like that I agree
Posted on: 2008/11/19 0:34
From The Shire Sydney
second that one....
Posted on: 2008/11/19 2:05
Life is like a pair of dice... you will never know what it will land on.
U bite me, i attack u!!
« 1 2 (3)
