#1 mynew grille wont fit
gxcoupe Posted on: 2008/11/18 23:22
got my car back went to fit new gx grille and none of the mounting holes line up any ideas
#2 Re: mynew grille wont fit
twin-idfs Posted on: 2008/11/19 8:52
drill some new holes??????
#3 Re: mynew grille wont fit
wolki101 Posted on: 2008/11/19 9:37
i know that when you try to fit a coupe style grille to a 1200 with a metal grille you need to weld new brackets on. i found out this the hard way when i bought a coupe style grille off ebay and nothing was there to connect it to.
not sure about if the gx grilles are different though.
#4 Re: mynew grille wont fit
gxcoupe Posted on: 2008/11/19 10:29
[img] Report Top
#5 Re: mynew grille wont fit
gxcoupe Posted on: 2008/11/19 10:31
not lining up
#6 Re: mynew grille wont fit
gxcoupe Posted on: 2008/11/19 10:35
not lining up at bottom metal tags from plastic grille in way was told this grille was on a coupe and was no modifications
#7 Re: mynew grille wont fit
1200rallycar Posted on: 2008/11/19 11:51
yeah that looks pretty whacky
how the hell will a headlight fit in that, looks like the grill sits 6inches forward of where headlight is
and there appears to be no mounting holes for top
thats nothing like a coupe grill
#8 Re: mynew grille wont fit
gxcoupe Posted on: 2008/11/19 12:04
once i remove mounting tabs for plastic grille the mounting tabs for new grille line up with two square holes but not on top is this where yours is bolted pepper
#9 Re: mynew grille wont fit
tommo73 Posted on: 2008/11/19 12:07
sunny grill ??
#10 Re: mynew grille wont fit
gxcoupe Posted on: 2008/11/19 12:14
was bought as a gx 1200 grille and they said it was on a coupe but originally on a sedan
