**can anybody say "KLEPTO, Hitachi, and EFI is evil"**
From Freo
out of what I count as 14 Hitachi carbs,
2 round tops, (L series manifold)
1 pair have what looks to be factory block off plates for the air bypass,
4 missing needles,
3 A series manifolds,
one looks to be early casting, the other two are similar, but a different threaded bosses here and there,
I managed to make 1 complete set of linkages out of the lot,
looks like the rest have been modded from L series gear, or there's bits missing, welded on wired up or just general dodgeyness...
not sure what factory GX manifold or linkages look like, I assume the ports are bigger and raised somewhat,
so what really had twins...
from the tech section, the A14t manifold looked different again..
the mind boggles...
Posted on: 2008/11/25 12:18
A15 PSI Project Motor
'72 CB750k,
Re: **can anybody say "KLEPTO, Hitachi, and EFI is evil"**
From Perth
Hey efi is evil ey???
Where did all those carbs come from ey?? maybe there is more efi dattos out there. lol
My datsun/ford/yamaha A14 is going fine although im running excessive timing after 4k 40deg.
Posted on: 2008/11/25 13:48
From Freo
of course EFI is evil..
what better fuel metering device could one have other than variable venturi, variable main jet system..
or the awesome DCOE, DHLA, Solex.. sideys..
Posted on: 2008/11/25 23:44
'72 CB750k,
From Tamworth , NSW
hey dundee, do you wanna part with 2 fuel bowl tops with the little float valves and levers intact?
Posted on: 2008/11/25 23:46
From Perth WA AUS
Emission controls? Just rip it all out! Let the new cars save the planet!
Posted on: 2008/11/26 8:53
Datsun 1200 2Dr sedan.
From Perth
Hey just leave the fuel delivery to us playstation generation. EFI can be tuned on the fly. Also my EDIS programmable ignition is FAR superior to any dizzy. You can program it to put any advance at any load at any revvs. Lets see a dizzy do that.
Ignition aside yes you can tune a carb to perform as well as EFI. But a well tuned sequential ignition will get far better economy than any carb. and can be programmed while driving to be in performance mode giving more power than economy.
My car is going in that direction. I want a switch that I can put the car into economy mode for daily and a switch to go into drag racing mode. you can only do that with EFI and electronic ignition.
Posted on: 2008/11/26 10:01
and when ems pulses make the all the electics in the world useless, us carb guys should be able to jump in out cars looking for oil mad max style.
Posted on: 2008/11/26 20:52
And of course we will overlook the fact that the EMP that kills the electrics that make the EFI work, will also kill the ignition.
Just a mere triviality
When the EMP hits, the only thing driveable will be hand cranked diesels, or diesel powered vehicles with manual trans that get parked nose down on hills.
Posted on: 2008/11/27 0:55
Love your Datsun.
Treat it well.
From Freo
I was waiting for Dodgeman to call in with some support.. ha ha..
Posted on: 2008/11/27 1:03
'72 CB750k,
how will emp kill points based dizzys? maybe elec dizzy but why points based, we can push start them too?
Posted on: 2008/11/27 1:56
« 1 2 (3) 4 5 »
