Think my datto has the flu..
From Wagga Wagga, NSW
Im driving to work doing 70-100 and just sitting on a speed and accelerating she'll cough and spit. Should i give it some nasal spray? (carby cleaner) and check my sparks and crap?
Posted on: 2008/11/27 5:46
Re: Think my datto has the flu..
Check your spark plug wires.
Is it a twin-carb? Check the carb synchronization.
Posted on: 2008/11/27 5:59
From Adelaide, Australia
How olds your fuel filter?
Posted on: 2008/11/27 7:03
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
just checked/cleaned everything. all good. nah stock carb. it seems it wont idle smoothly either. itll idle bout 900 then sound like its gonna stall.
fuel filter is quite new. couple months maybe.
Posted on: 2008/11/27 7:05
From bathurst nsw
tried points gap, condition of the rotor button and the dissy posts inside the cap?
check your timing at static and full advance too and make sure the dissy isnt stuffed
Posted on: 2008/11/27 9:33
My car gets me from A to B...Just faster ;)
points gap i understand. but rotor button and dizzy points, static and full advance now im lost.
Posted on: 2008/11/27 9:59
think its my distributor woody, its making a mad noise and everytime it makes the noise the tacho goes crazy. Does it need replacing?
edit: are a12 and a14 dizzy interchangable
Posted on: 2008/11/28 22:30
take your filter off and hold it upright and shake the fuel out of the bottom into a glass or a something u can see through...
check that it doesnt have beads of water in the bottom... i had similar problems with my ute.
took me ages 2 work out...
Posted on: 2008/11/28 23:51
its cool. was me dizzy. went and got another one this morning from an a12 and swapped it. all is good now. learnt timing and #### at the same time.
Posted on: 2008/11/29 10:47
