whats the timing for a stock a12 motor and the fuel and air mix?
Not too shy to talk
From Rockhampton QLD
ive just bought a datto ute it has a stock a12 and theyve stuffed around with fuel and air mix and the timing so i was wondering if anyone new wat they are so i can put it as that? i need to know asap. thanx
Posted on: 2008/11/29 9:04
Re: whats the timing for a stock a12 motor and the fuel and air mix?
Not too shy to talk
oh and also what the points gap should be please?
Posted on: 2008/11/29 9:13
From Murray Bridge, SA
prob better off popping it in the main forum mate,
then ull get the answer to ur question
Posted on: 2008/11/29 11:50
Cars:
1973 Datsun 1200 sedan (Project)
19?? Datsun 1200 sedan (Parts Car)
A12 crankin
From Albuquerque NM, USA
dizzy point gap.....0.18 to 0.22
static ignition timing 7degrees BTDC @ 600rpm
except north america 5 degrees BTDC @ 700 rpm
This info is from a Haynes manual 1970 thru 1973. (USA)
Don't know about fuel/air ratio
Posted on: 2008/11/29 18:55
Not too shy to talk
thanx for that "kelmo" put it at 7 degrees btdc and fixed up the points gap and runs good as now
Posted on: 2008/11/30 8:25
From Launceston, Tasmania
I usually run the timing a couple degrees more then standard. I run mine at about 10 degrees btdc.
Posted on: 2008/11/30 8:37
