I recently managed to get my rebuild running after much confusion and fiddling I have it idling near 1000RPM and one carb piston sits higher (i.e. more air flowing) than the other no matter how I position the idle screws or mixture screws on that carb. So it's a bit lumpy and it doesn't want to respond to throttle jabs without bogging down.
Anyway - theres a squeaky kind of rattle that sounds like it's vibration triggered and it comes and goes at idle and sounds worse as the revs go up. It sounds like it's near the front of the block.
I assumed it was water pump or belt related so I disconnected the belt and ticked it over for 10 seconds or so (so that alternator, water pump and fan were not running) and the noise was still there.
I think I will try and use a stethoscope or something to locate the origin of the noise.
The wierd thing is that it was lovely and quiet under starter motor and would spin and spin - sweetly and cleanly.
Now it's running under it's own power it has a squeak.
I've checked engine mounts and they're all tight as can be. I've listened to the valve train with the oil filler cap off and it seems normal in there.
Could there be a problem with the timing chain / tensioner or something in there?
Any ideas or suggestions would be greatly appreciated.
