Wanted : Urgent!!! Perth WA, stanza strut conversion parts
From Perth
As above. needed new or near new rotors for me 1200 coupe. or parts to finish my stanza struts, I have the struts and arms/axels. I am missing the 120y castor rods and rotors and calipers. someone said that r31 ones would fit. so I got some r31 rotors and discs. the discs wont fit, the calipers will but wont fit with the discs on!
cheers -Liam
Posted on: 2008/12/1 9:26
Re: Wanted : Urgent!!! Perth WA, ROTORS 1200 Coupe
From Perth WA AUS
I have one disc rotor to suit a 1200 coupe, (not undersize)
0433 045 155
Posted on: 2008/12/1 12:45
Datsun 1200 2Dr sedan.
From Perth
is it a new one dude??
Posted on: 2008/12/1 14:40
From Perth WA AUS
Nah, not new. I got my new ones through Odin Auto Parts (Brembo discs)
Cant remember price, but wasn't too bad.
Posted on: 2008/12/2 5:46
From Perth
can you gimme the numbers or something that I can take to them so they gimme the right thing. or did u get em for 1200 struts or stanza struts??
Cheers -Liam
Posted on: 2008/12/2 11:07
From Perth WA
you can buy standard rotors for any car on the road pretty easily.
But sounds like you dont know what rotor you need.
PM Pigdog or somebody like that, hes a strut nutter. Or make a more open titled thread, sounds like yuo want rotors in WA.
Posted on: 2008/12/2 12:18
Chris...
From perth airport
you have stanza struts yes? then use stanza rotors , there bigger than 120y
i forget if you use the stanza lower control arm or the 1200 one but its a pretty simple convershion
Posted on: 2008/12/2 20:44
perth airport parking
Datsun 1200 ute A14
From Perth
yeh got the struts and stub axels, ball joint and LCA, also the castor rods, but I heared that you cave to rethread the stanza castor rods. I also heared that the 120y castor rods can be used. I think I might pm pigdog. I need a supplier for the stanza stuff to complete my stanza conversion.
Cheers -Liam
Posted on: 2008/12/3 9:15
you could if in a squeeze just use the 120 castor rods and machine (read angle grinder) the circular cut out in there as they are the same length as the 120y ones. only issue is theya re a 8mm bolt not 10mm bolt. So as i had a discusiion with 1200rc and supafatto, small bolt in a big hole not good but will get you by till you get the 120y ones.
Posted on: 2008/12/3 9:34
From Perth
did u mean the 1200 castor rods for a cutout??
Posted on: 2008/12/3 11:42
