Browsing this Thread:
i need help with me brakes
Not too shy to talk
From Rockhampton QLD
hey ive got a 85 1200 ute and when i push the brake pedal down it doesnt go all the way to the floor but it just about does and you can only just feel the brakes grab so we bled the brakes and there was still no difference. its got drum brakes all around. can anyone help?
Posted on: 2008/12/6 8:13
Re: i need help with me brakes
From Armidale N.S.W
Have you checked all ya lines for leaks and adjusted the brakes ? What order did you bleed them in ?
Posted on: 2008/12/6 8:18
73 1200 wagon SOLD
Not too shy to talk
nah i havent checked the lines for leaks and my step dad had a look to see if there was anything to adjust them but he couldnt find anything. umm back passenger, back drivers, front drivers, front passenger.
Posted on: 2008/12/6 8:20
From Armidale N.S.W
There is a little square headed bolt on the top it will be visible when you look up from underneath the car, get a torch if necessary. You dont have to take off the wheels or anything just may need a shifter or the correct fitting spanner. tighten them like a normal bolt to the right bit by bit. keep checking as you go but a sudden loss of pedal sounds like somethings given out.
Posted on: 2008/12/6 8:27
73 1200 wagon SOLD
From Melbourne, Oz
I think it will allmost scertenly be that the pads are just two far from the drum? you may need new pads with more meat or you can just adjust them with the 17mm bolt heads on the rear of the drum aitch turn a snale shell shaped cam witch lifts the rest position of the pad..
try driving as it is and pumping the bracke peddle quickish if the come on after the second or third pump than that will be the problem..
Good luck
and what andy sed for the back break's!
"I hav achieved wood"
From Geelong, Vic
do they get better if you pump them?
Edit: what ROConnor said
and for the rear drum adjustment there is a small square doover poking out of the backing plate near the top
Posted on: 2008/12/6 8:29
From Perth WA
Is the pedal still hard at that level? If it is your brakes are out of adjustment. Buy a workshop manual and adjust them up (very easy) or take it to a brake shop to do.
If the pedal is spongey and will 'pump up' to a better higher pedal i would say hydrolics are farked. Is the level still full? If it is could be a brake master cylinder.
Also what condition are your brakes in? For all we know you could be trying to adjust completely worn/leaking brakes with mud for brake fluid!
Posted on: 2008/12/6 8:30
Chris...
Not too shy to talk
yep ok then thanks for that fellas hopefully that works. thats how the brakes wore when i brought the car so i dont exactly know whappend to them
Not too shy to talk
yea they need to get adjusted cause the drum was a bit loose when i pulled it off to check the pads but when my step dad looked to see if there was something to adjust them he couldnt find it so he thought maybe they would adjust if we bled them and theres plenty on the the pads and the fluids still full and its clean brake fluid. ill adjust the pads tomorrow coz its a bit dark to do it now and hopefully that fixes the problem. after i adjust the pads will i need to bleed them again or should they be right?
Posted on: 2008/12/6 8:39
From Armidale N.S.W
Maybe bleed them again for arguments sake. possibly your step dad was looking for an adjustment internally like some old Holdens but there is no need to remove anything the adjustment is external but up on the inside. Will post a pic later to save any confusion, unless someone can beat me to it. Hint Hint
Posted on: 2008/12/6 9:04
73 1200 wagon SOLD
