Re: A12 GX Compression Readings
All the books say it should be done with the throttle fully open, however I've never seen a significant difference when leaving it closed.
Posted on: 2003/7/10 16:09
Subject Poster Date
     A12 GX Compression Readings britishcarfreak 2003/7/3 1:12
       Re: A12 GX Compression Readings Buff 2003/7/3 1:15
         Re: A12 GX Compression Readings britishcarfreak 2003/7/3 1:17
           Re: A12 GX Compression Readings Buff 2003/7/3 1:30
             Re: A12 GX Compression Readings ddgonzal 2003/7/3 3:59
               Re: A12 GX Compression Readings britishcarfreak 2003/7/10 7:58
                 Re: A12 GX Compression Readings feral 2003/7/10 10:02
                   Re: A12 GX Compression Readings ddgonzal 2003/7/10 16:09
                     Re: A12 GX Compression Readings feral 2003/7/10 22:37
                       Re: A12 GX Compression Readings britishcarfreak 2003/7/10 23:42
                         Re: A12 GX Compression Readings britishcarfreak 2003/7/15 2:06
                           Re: A12 GX Compression Readings feral 2003/7/15 2:25
                           Re: A12 GX Compression Readings feral 2003/7/15 2:28
                             Re: A12 GX Compression Readings britishcarfreak 2003/7/15 7:28
                               Re: A12 GX Compression Readings feral 2003/7/15 12:12
                             Re: A12 GX Compression Readings bobs1200 2003/7/15 16:10
                       Re: A12 GX Compression Readings ddgonzal 2003/7/16 7:40
                         Re: A12 GX Compression Readings britishcarfreak 2003/7/16 7:44
                           Re: A12 GX Compression Readings ddgonzal 2003/7/16 7:50
                             Re: A12 GX Compression Readings britishcarfreak 2003/7/16 8:00
                               Re: A12 GX Compression Readings ddgonzal 2003/7/16 8:19
                                 Re: A12 GX Compression Readings britishcarfreak 2003/7/16 12:23
           Re: A12 GX Compression Readings bobs1200 2003/7/16 17:34
             Re: A12 GX Compression Readings britishcarfreak 2003/7/16 22:58
               Re: A12 GX Compression Readings ddgonzal 2003/7/16 23:43
               Re: A12 GX Compression Readings bobs1200 2003/7/17 1:00
                 Re: A12 GX Compression Readings britishcarfreak 2003/7/17 1:48
