Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
F5C56A help
DatsunSSS
Posted on: 2008/12/7 15:15
I havea 56A 5 dogleg five speed that needs to be fixed.
One bearing is completelly destroyed and the sincros are in bad shape. Were can i find some new sincros, or can i make new ones? And what about the rebild manual? were can i found? thanks in advance
#2
Re: F5C56A help
Fandatstick
Posted on: 2008/12/8 10:26
Not sure if you can get new syncros but you can replace them with standard 56A syncros (eg servicable used ones). May need to replace each pair if the ones in your 5 speed are the steel type rather than brass liek 4 speeds.
Bearings - take the worn ones to any bearing outfit and ask for replacements.
#3
Re: F5C56A help
DatsunSSS
Posted on: 2008/12/8 18:01
the standard 4 speed syncros fits the 5 speed 56A gearbox?????
#4
Re: F5C56A help
Posted on: 2008/12/8 23:44
4-sped and 5-sped synchros are very different.
Nissan Part Numbers 4-SPEED EARLY * 32601-18000 HUB-SYNCHRONIZER 1 4 SPEED * 32604-H1000 BAULK RING * 32606-18000 SLEEVE-COUPLING LATE * 32601-H7301 HUB-SYNCHRONIZER, 1ST & 2ND, 3RD & 4TH * 32604-H9000 BAULK RING * 32606-18000 SLEEVE-COUPLING 5-SPEED * 32601-H7200 HUB-SYNCHRONIZER, 2nd & 3rd, 4th & 5th 5-speed * 32606-H7200 SLEEVE-coupling
#6
Re: F5C56A help
Fandatstick
Posted on: 2008/12/9 9:14
Yes - but they can be swapped for the standard brass/4-speed type and work fine. You'll need to press the cone off the gear and press on the one to match the brass type. Works fine in my one ![]()
#8
Re: F5C56A help
DatsunSSS
Posted on: 2008/12/9 12:43
DD i have that manual, but dont have the 56A five speed
#9
Re: F5C56A help
Posted on: 2008/12/13 10:28
You may need the Japan-market service manual, since that was the only place this transmission was sold. It will be in Japanese, but all the measurements are easy to pick out.
