Gearbox is in!!!!
From brisbane
I got it. The problem was the rb output shaft was too long for the ca bell. That was going right through the spigot bush and hitting the crank. Lopped 20mm off the end of the output shaft and it slipped right in. Buisly having tailshaft shortened and balanced, and making up gearbox crossmember mounts.
Thanks for your help fellas,
might make it just in time for the cruise
acutally looks like a car that will move now
mely
Posted on: 2003/7/11 0:22
Re: Gearbox is in!!!!
From sydney australia
who'da picked that the first time.nothing an angle grinder couldn't fix,but.
Posted on: 2003/7/11 10:31
