Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#3
Re: ca18 engine parts for sale
datsunb120
Posted on: 2008/12/8 5:37
what ever you see is whats for sale. except the exhaust
name a price
#4
fx215matt
Posted on: 2008/12/10 0:25
Thanks for the sump. Top bloke to deal with
Cheers Matt..
#5
PIGDOG
Posted on: 2008/12/10 2:48
do you have any flywheel bolts, need to be flywheel ones not flex plate ones
maybe the CAS, and is it the cam or the sproket that has the splines that the CAS goes into? might be interested in that also
#6
dattodude
Posted on: 2008/12/10 3:04
The CAS pushes into the exhaust cam. All the locating stuff is in the cam.
#7
PIGDOG
Posted on: 2008/12/10 3:20
that could make it a bit harder to use on something else then
#8
dazza1200
Posted on: 2008/12/10 11:38
main caps MUST stay with correct block
cam caps MUST stay with correct head pigdog there are easier cas's to use for conversions. mits 4g63 dohc comes to mind. has flat offset drive slot/key ca has 8 spline w/ indexing tang (hard to replicate). you could machine the shaft for diff drive You can view topic.
