Thanks to all who replied.
Just some more questions to add on please.
1. Coolant flush is fine with me, but my main concern is that there is also a drain plug on the engine block itself and a drain plug on the radiator bottom left corner.
Must I drain the radiator and also the engine block or will only the radiator do.According to the Haynes manual they only talk about flushing the engine block when coolant change has been neclected.So I don't know if I must drain the engine block aswell if it was serviced all the time by previous owner at Nissan and also if I am going to use the same collant as was used at Nissan.
We have a saying here that says "Don't scratch where it doesn't itch". So, I don't want to really remove the bolt on the engine block to drain unless it really is required reason being that it might leak afterwards or something else.
Power steering. If I use a different power steering fluid as what is currently in it, will it have a negative effect? I know that it is not good to mix different oil brands, but what about power steering fluid.
By the way, the car has currently 75 000km on the clock. (Sorry, don't know how many miles that is
