Power down, can anyone help
From Bathurst
I drive a 69 1000 Coupe. I had to change the spark plugs to B4s (previously B5s) cause they burnt out way too quickly, sounded like my car was miss firing. So i put optimax and flashlube in it now in stead of leaded fuel, and it feels like i've lost power. Any suggestions, would be appreciated.
Ta
Posted on: 2003/7/13 9:56
The beauty of it is, no one sees it coming
Re: Power down, can anyone help
From sutho shire
try giving your car a full service going over the leads and change oil optimax did same 2 my ute and i just did a service and seem 2 pick up better! good luck!
Posted on: 2003/7/13 10:44
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
already did.
From Bathurst
I just had it serviced like a month ago, and then last week i changed the plugs and tuned it up a notch or 2 (or 3) and it went like crazy. Perhaps it was just the batch of fuel i had. It seemed alright when i put normal unleaded in it, but when i put optimax in it just went to ####.
Posted on: 2003/7/13 10:56
From GOLD COAST AUZ
advance timing to 10*or 11* advance.
back fire from carb is to lean,burnt valve or burnt head gasket.MITE HELP A BIT
Posted on: 2003/7/13 11:13
rather be a old fart than a young d##khead
Sounds like you got a bad batch of fuel. Have you put different fuel in since the optimax? Get rid of the optimax and just run normal unleaded. You shouldn't need any higher octane.
But if you ever do need it I recommend BP Ultimate over Optimax, as I've heard of people getting bad batches of optimax before.
By the way, what 1000 parts have you got? Don't have a bonnet do ya???
Tim
Posted on: 2003/7/13 11:22
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
From Auckland N.Z
do NOT advance the timing more than 8deg. it will pink and kill your motor. ive got a worked 1200 running on av gas and its only on 7-9degs. no need to go higher.
Posted on: 2003/7/13 13:30
Query the fuel quality.
The Porsche Club have had all sorts of trouble with Optimax and it may go so far as to involve damaged engines.
Also, the Datsun Roadster guys also has trouble a couple of years ago
Avgas is better if you are running more than 10 to 10.5 to 1 comp.
Posted on: 2003/7/14 2:20
Avgas
From Bathurst
What is this avgas you speak of?
Excuse my ignorance.
Posted on: 2003/7/14 7:52
Re: Avgas
Avgas is aviation fuel...available from airports in large quantities. Illegal for road use due to extremely high lead content.
I've heard that is anywhere up 110 octane
Posted on: 2003/7/14 8:11
Lead
From Bathurst
Does it make a difference if you your put more than the recommended amount of flashlube in your tank. Is it bad?
Posted on: 2003/7/14 8:20
