tails shaft lengths.
hi all, trying to find out wht the length of an auto 120y tail shaft is and a manual one. I have a manual one in the car and it measures at 1240mm from diff flange to the lip of cup over the gear box extension housing, the auto one is 1290mm same measurements? i thought the auto should be shorter by 50mm not longer?
Any help out there? i have a h150 in the car but auto and manual h145 and h165 tailshafts should be same lengths. (h165 in 1200 would only have a manual tail shaft as i dont think they ever came behind n auto in aus factory)
another hurdle in the cheap/slow L conversion
Posted on: 2009/1/10 6:15
Re: tails shaft lengths.
<-- wiki clicky, search for: Propeller Shaft Swaps
See Propeller Shaft Swaps for:
* Part Numbers
* Specifications, including length
* Swap information
* Dimensions
Posted on: 2009/1/10 6:55
thanks dd, i stuglled to find it in wiki, found it in sunny manual i had and a 120why one
Posted on: 2009/1/10 9:29
