South African users
Hi guys
Can anyone tell me where i can get cams for my A14s motor?
Posted on: 2009/1/12 13:10
Re: South African users
Nissan South Africa sells A14 cam
Posted on: 2009/1/12 17:04
From Krugersdorp,Gauteng,ZA
Waar Suid Afrika is jy? Where in ZA are you?
Posted on: 2009/1/12 17:32
From Cape Town ZA
I think he's referring to something wilder than a standard cam, or even the GX ones. If they do sell it would more than likely be the standard A14 cam anyway.
Try Lamco Developments in Pretoria, they are legendary with the A series motors, and also the Ford Kent engines, as far as cams go...
Posted on: 2009/1/12 20:08
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Im am in Port Elizabeth...
Would also like to convert to electronic ignition...is this a difficult mod to do myself?
Posted on: 2009/1/13 7:36
From South Africa, Bloemfontein
PM Clive on this site. I helped him with some stuff and he also helped me with some stuff in Pretoria. As far as I know he also knows someone at Lamco developments.
What spec cam are you looking for?
Install a Pertronix ignitor. VERY easy to install and makes a big difference.
Posted on: 2009/1/13 10:52
1977 Datsun 1200GX
From South-Africa,Pretoria
hey, yeah if u want the number of uncle lammies @ lamco i can give it. I prefer to talk to him directly. Otherwise u could try Camshafts dynamics in Jhb, im currently running one of their cams. will add a clip of the bakkie once iv sorted out a few issue's ^__^
Posted on: 2009/1/13 16:45
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
Hope you are sorted with the cam. I used a E16 (Box shape Sentra) dist. Cut away the adjustment slot. Screw the A14 dist base plate to the new dist. Put over the A14 dist gear turned around. Drill a hole for the gear pin. Easy. Swop the coil as well.
Posted on: 2009/1/13 18:26
