Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Polished Diff Gears.
Daveman
Posted on: 2009/1/13 3:39
There's no reason you couldn't make straight cut diff gears - in that they are non-helical. There still needs to be some tapering on the gear but that is different and is what is required to transfer the torque axis by 90 degrees.
#12
ratsun_a14
Posted on: 2009/1/13 3:41
what would u recomend polishing the diff gears with? wire wheel? or is their some speical tool to polish the gears with?
#13
levey
Posted on: 2009/1/13 10:24
Yeah good tip, I might polish my roll cage to make it stronger! :) just kidding, really!
#14
revhead001
Posted on: 2009/1/15 11:11
Firstly the gears get soaked in acid for about 8 to 10 hours and then they get placed into a container filled with ceramic stones shaped like triangles. The container is also filled with a solution that has a chemical reaction th the acid causing the gears to vibrate. After about another 10 hours you pull the gears out looking like chrome plated gears. At about $2K for a crownwheel / pinion you would see the point in making it last as long as you can.
#15
datokid
Posted on: 2009/2/16 7:00
i wonder were i could get them done around mandurah
#16
1200rallycar
Posted on: 2009/2/16 7:06
DID IT WORK? any decent result from doing it?
#17
aidaniel
Posted on: 2009/2/16 8:11
i have one of those polishers at work, might invest in some different grade stones and give something like this a shot
#18
levey
Posted on: 2009/2/16 10:19
Are you guys taking the piss or what?
I Suppose a smooth surface would reduce wear a fair bit.
#19
1200rallycar
Posted on: 2009/2/16 10:29
not sure who your asking but i geuinely want to know what percentage benefit this would give?
#20
revhead001
Posted on: 2009/2/16 11:10
The season kicks off shortly for the GT3 lads and we will not know for about 6 months or more when we get the box back. It will work, as it has been proven in the past with regular ol straight cut gears. GRM has been doing it for years and with our SG gearbox's that were dropping a tooth off, after polishing they have not needed to replace gears yet. They are homoligated in the Focus rally car somewhere in europe and they can only buy our gears so it does work. We have just never tried it with diff gears. When you buy a C/P from Astin Martin for racing purposes they come polished. It must do something. You can view topic.
