« 1 (2) 3 4 »
Re: V6 Transplant
From Canberra
Here is one that V&E Rigoli did for a customer a few months ago that's twin turbo
Posted on: 2009/1/17 0:26
Re: V6 Transplant
From Geelong, Vic
yeah the fit in pretty easy in the engine bay, i needed to make some custom headers up so that they would fit past the steering box and odler arm. but now the V6 actually sounds like a real engine, unlike pretty much every other commodore v6 out there
only had to cut into the firewall as i dummied the engine up without the throttle body on it, and then it just fit the firewall when i put it in.
theres plenty of room in front of the engine for the radiator and such, pretty sure an L series is longer than the v6
trans tunnel would be a fair bit of work as the autos are huge, but nothing a new tunnel wont fix
and yeah probably wouldnt be any good for any kind of mid to high speed cornering with all the weight up the front...could just run semi slicks all the time
wouldnt really say it was a good idea for a road car unless you were after a burnout car that you wanted to drive on the street. coz its never going to be legal either
saying that mine with a stock engine, stock auto, 3.9 gears and 185 14s has no problem finding limiter on the spot in top gear. hoping it can still do it with 3.08s and 205 15s
Posted on: 2009/1/17 1:28
Re: V6 Transplant
From Melbourne ( West )
Wow!!!
That Rigoli Ute is really neat - everything fits well too.
Even though a V6 would have more weight than a CA or SR for example, I'm guessing the weight would be spread wider rather than longer - given that the Cylinder banks would only be three deep on each side - as opposed to four in a line.
Weight would obviously play a huge part in handling, but isn't weight more critical when it's extending past the crossmember / front wheels?
(This is not fact - just a thought)
But, The new Alloytech V6 Commodore engine could be fun - anyone know it's weight?
Posted on: 2009/1/17 1:31
'78 Ute CA18det Project
No matter where you go... There you are
Re: V6 Transplant
From perth
ask yourself 1 question "do i want to go around corners?"
if the answer is no then go the v6
put it as far back as possible
if the answer is yes then find another way
an sr is too heavy!
rigoli ute? beautiful drag car. but you can bet it would be horrible to drive on the street even with the right wheels
dazza
Posted on: 2009/1/17 4:01
Re: V6 Transplant
A V6-powered 1200 can go around corners. How well is the question. I would say if you did the suspension right, it would go around corners better than a stocker 1200. If you put the V6 back enough, it will go around corners better than your typical CA18DET-powered 1200.
As they say, it's all in the details.
Posted on: 2009/1/17 5:04
Re: V6 Transplant
From Perth WA
Theres your answer! Mid mount it!
Posted on: 2009/1/17 6:44
Chris...
Re: V6 Transplant
From perth
i think you would need to recess firewall at least 6" to get same f/r weight distribution as a ca 1200
Posted on: 2009/1/17 9:27
Re: V6 Transplant
From newcastle, NSW
you could only use it from a drag or burnout car, the amount of work needed to 'mid-mount' a holden V6 would be astronomical! to me it would defeat the purpose.
Posted on: 2009/1/17 10:03
Re: V6 Transplant
From Coondle, WA Australia
Since its pretty much consensus that its not a licensable option, its either drag or burnour car material, so in the end, how much cut and shuting you need to do is not really the point.
perhaps you could mount it backwards like a VW and make it front wheel drive...
Posted on: 2009/1/17 10:13
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: V6 Transplant
From Geelong, Vic
to make the worst 1200 in the world?
Posted on: 2009/1/17 10:43
« 1 (2) 3 4 »
