(1) 2 3 »
what turbos are people running?
From Griffith
Hey everyone ive decided to go down the path of turboing my a15 , i would just like to know what turbos poeple are running on there a serires motors, im after a small to decent size turbo that can hold a nice amount of boost say 10 to 15 psi , with least or no lag at all. also i want to run twin side draft 40dcoes can any one see problems that may occur buy running these ?
Any help would be appreciated
Cheers Alfie
Posted on: 2009/1/18 6:59
Re: what turbos are people running?
From newcastle, NSW
Most people tend to use a T25 off a CA18det, its a little laggy when useing a T25 but when it comes on boost its like a friggin hurricane!
I first used a T2 from a ET pulsar and it was pretty well suited but it ran out of puff in the higher RPM range.
I have heard of people using a turbo off a toyota starlet, CT12 or something similar. They have a different flanges to the nissan/garrett turbos, they are also well suited to an A series engine.
Possibilities are limitless, all depends on your budget and degree of knowledge, and also what you intend to use the vehicle for.
As for using twin 40 DCOE's in a turbo set-up there is a member on here that developed a twin webbered turbo set up, his name is Kegs. It is possible with some good results. Shoot him off a PM.
Posted on: 2009/1/18 7:20
From Griffith
Thanks steveo that gives me a good idea when you say laggy how laggy?
i was kinda leaning towards this or is it to big and lots of lag?
http://www.turbobygarrett.com/turboby ... /GT15/GT1548_466755_3.htm
i reckon it might be bought rite but not sure thats y i am asking u guys
Yea i seen a couple of posts from kegs i might send him a pm
Posted on: 2009/1/18 7:30
From newcastle, NSW
That should be pretty much spot on for an A-series, i would go for the T25 plenty of them around and heaps cheaper, boost comes on around about 3500-4000rpm. heaps of fun!
Posted on: 2009/1/18 7:46
From Canberra
why does everyone hate lag so much? Its not that bad. My high-flow FJ20 T3 on a 1.6 was pretty laggy, but its not that hard to change down a gear and avoid the lag. Also means you can drive off boost for fuel economy.
Posted on: 2009/1/18 7:52
From perth
NA motors always on lag!
Posted on: 2009/1/18 8:59
From Griffith
LOL at dazza
Tyrie you do have a point there never thought of it that way
Yea i was also considering the turbo the next step up think was gt2o series for little bit more go
http://www.turbobygarrett.com/turboby ... /GT20/GT2052_727264_2.htm
Either way i think its a good choice and at least i can pump out some more psi from it
Posted on: 2009/1/18 9:08
From South Africa
I'm running a GT1746(1749), like from a Merc 1.8Vito van. A beautiful little unit.
only mods required was to swop the vacuum actuaror on the waste-gate to a normal one that can sense boost... Good for 15psi from 2500RPM all the way through 7krpm into an A15.
Posted on: 2009/1/18 13:54
From Griffith
Kool that looks good , ive made my decision i think im going with the gt1548 should be perfect and can get one for about 600 bucks new if its not right go bigger lol
Im going to be anoying and ask another question what piston are you guys running , would standard pistons with chrome rings be able to handle boost if so how much boost ?
Cheers
Posted on: 2009/1/19 7:32
From South Africa
well, I was told by someone, in the know, that Langley turbo pistons are a straight swap.... it's not, they are too tall, 3mm in total, so I was stuck with them and had to make a plan, had 1mm chopped off the std A15 rods, and 2mm from the tops of the pistons, they where nicely dished to start with, so things actually worked out rather well in the end... I'm pushing the 290,000 Km mark here, and not a single glitch from her... lately though, I'm noticing a slight bit of smoke, when I lift throttles, figuring it to be the turbo's Turbine oil-seal that might be a tad bit on the going-out phase of it's life... these pistons are however more than capable of holding 15PSI all day long... as long as you keep detonation under control. For that I'm using a home made boost-regulating detonation detector.
Posted on: 2009/1/19 20:58
(1) 2 3 »
