#1 Fitting a B&M cable shifter to a Jatco 3-speed Auto..
spraycanmansam Posted on: 2009/1/21 11:11
As the title says, I'm wondering if I can adapt a B&M cable shifter to my 3N71B auto box?
I've had a search around and can't seem to find a definitive answer.. some say you can, some say you cant
..also there's a few wires on the box which I'm not 100% sure on where they go, are there any diagrams floating around?
Any help would be much appreciated
Cheers,
Sam
#2 Re: Fitting a B&M cable shifter to a Jatco 3-speed Auto..
WhiteSedan Posted on: 2009/1/21 11:14
Two wires should be for the reverse lights and two wires coming out the larger canister are for the neutral safety switch which should stop the engine starting in gear.
Sean
#3 Re: Fitting a B&M cable shifter to a Jatco 3-speed Auto..
pepper Posted on: 2009/1/21 11:14
dunno about the gearbox, but how about some pics of that rwd mini !!
#4 Re: Fitting a B&M cable shifter to a Jatco 3-speed Auto..
shaun Posted on: 2009/1/21 12:00
it can be done as i had a 3 speed jatco with a pro ratchet shifter in my ute
just takes patiences setting it up
#5 Re: Fitting a B&M cable shifter to a Jatco 3-speed Auto..
spraycanmansam Posted on: 2009/1/21 13:38
Awesome. Yep, I assume there will be some custom bracket work required.
I'll take some new progress pics of the Mini.
..and thanks Sean for the wires
