Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#31
Re: s13 struts
tom210
Posted on: 2009/1/21 12:43
so what your saying is the std 1200 outer tie rod end will still be ok to use? sounds too good to be true
#32
Re: s13 struts
lowendtheory
Posted on: 2009/1/21 15:03
well upon further inspection, and removal of my standard radius rods, the r31 rod is longer! I was expecting it to be shorter, is this correct?
The r31 rod is on the right [img]http://s160.photobucket.com/albums/t177/lowendtheory/?action=view¤t=IMG_0044.jpg[/img]
#33
Re: s13 struts
datsunsunny
Posted on: 2009/1/21 16:07
u have to use same tie rod but you will use s13 tie rod end. (both right side because of their thread)
#36
Re: s13 struts
lowendtheory
Posted on: 2009/1/23 22:41
Is an r31 radius rod longer than a standard datsun 1200 radius rod? or can someone please let me know how long an r31 radius rod is
#37
Re: s13 struts
datsunsunny
Posted on: 2009/1/24 15:28
the image is not shown but if it is longer u can always shorten it.
#38
Re: s13 struts
lowendtheory
Posted on: 2009/1/25 4:05
The point of buying r31 radius rods was that they are 'bolt in' I just want to know if I have the right item. I could have shortened my standard ones, I could of had custom ones made, I did not and do not have the desire to be stuffing around with everything, I just want to know if I have the right bit.
#39
Re: s13 struts
dazza1200
Posted on: 2009/1/26 3:11
let me get this straight
you have one of each, in your possesion and you want us to tell you which one is longer? try em and let us know
#40
Re: s13 struts
frankthedolphintrainer
Posted on: 2009/1/26 4:30
the r31 rods are about 27mm shorter from the foward bolt hole centre to the start of the thread
