Fitting a B&M cable shifter to a Jatco 3-speed Auto..
As the title says, I'm wondering if I can adapt a B&M cable shifter to my 3N71B auto box?
I've had a search around and can't seem to find a definitive answer.. some say you can, some say you cant
..also there's a few wires on the box which I'm not 100% sure on where they go, are there any diagrams floating around?
Any help would be much appreciated
Cheers,
Sam
Posted on: 2009/1/21 11:11
Re: Fitting a B&M cable shifter to a Jatco 3-speed Auto..
From Adelaide, Australia
Two wires should be for the reverse lights and two wires coming out the larger canister are for the neutral safety switch which should stop the engine starting in gear.
Sean
Posted on: 2009/1/21 11:14
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Tamworth , NSW
dunno about the gearbox, but how about some pics of that rwd mini !!
From penrith,sydney,aus
it can be done as i had a 3 speed jatco with a pro ratchet shifter in my ute
just takes patiences setting it up
Posted on: 2009/1/21 12:00
2 door 1200 sedan project l20b stroker
Awesome. Yep, I assume there will be some custom bracket work required.
I'll take some new progress pics of the Mini.
..and thanks Sean for the wires
Posted on: 2009/1/21 13:38
Edited by spraycanmansam on 2021/1/27 7:04:12
