#1 Gearbox for my 1200 ute
-Hutch- Posted on: 2009/1/25 22:30
I am just about to start my project and i am in need of some help.
I am going to put a CA18DET engine in my 1200 ute and was wondering what gearbox would be the best. I have been told a CA gear box will fit and the shifter should only sit about 15cm rear of the old shifter point. Or go and get a R30 stumpy with a CA bellhousing.
Is there a prefered gear box for this converstion
Thank you
#2 Re: Gearbox for my 1200 ute
hotrocket Posted on: 2009/1/25 23:11
ive kept the ca box can handle what you give it,, where stumpbox (r30) wont for long,
not much is needed to tranny tunnel for fitment just sum little changes
#3 Re: Gearbox for my 1200 ute
-Hutch- Posted on: 2009/1/26 0:37
I have heard that the CA box is a lot stronger. Is there any particular version of CA that i should be using?
Thank you
#4 Re: Gearbox for my 1200 ute
hotrocket Posted on: 2009/1/26 0:42
did you get a box with the ca?,
S13 silvia there just standard boxes.....if your not using silvia gauges cluster then you must use a L series speedo drive to replace the electonic one in the CA box, cables from Maddat.com
#5 Re: Gearbox for my 1200 ute
-Hutch- Posted on: 2009/1/26 0:53
Thanks hotrocket you are a champion.
No i did not get a box with the engine i am doing some searching now for one.
I am lookoing at putting autometer gauges so i guess i will just buy some that match the gearbox
#6 Re: Gearbox for my 1200 ute
hotrocket Posted on: 2009/1/26 5:37
give sum of those jap wreckers ago or try nissansilvia.com
scout around ebay or oztion you do see them there sumtimes,
autometer white or silver face?
#7 Re: Gearbox for my 1200 ute
-Hutch- Posted on: 2009/1/26 9:35
I am not sure what colour i will go yet. White always looks good at day time but it gets bright at night time unless it is dimmed right down.
