#1 Datsun 1200 ute CA18DET mod - Help
-Hutch- Posted on: 2009/1/27 3:42
I have a few (by few i mean alot) questions regarding this mod and hoping to get some help.
> Engine mounts for the CA18DET (any pictures of a modified cross member so i can build one)
> Brake upgrades, will a 120y/180B/200B brake setup mount directly into the 1200?
> Tunnel Mod to suit a CA gearbox?
> What is the recommended diff for this package?
> Is there anyway to convert the front hubs to 5 stud?
> i am looking at buying a complete parts car to pillage for the mod what would be best suited (120y/180B etc)
I know these answer have probabily be answered before but any help is greatly appreciated.
Thank you
#2 Re: Datsun 1200 ute CA18DET mod - Help
Montebello1200 Posted on: 2009/1/27 3:49
120y,b210 fit perfectly they bolt right on. thats all i know.lol.. umm im looking for a wind shield got any ideas???
#3 Re: Datsun 1200 ute CA18DET mod - Help
hotrocket Posted on: 2009/1/27 3:53
im in the same boat lol,
im keeping s13 box just changing the tunnel to 120y,
im fabing up my own mounts on the x-member, if your able to do so try Maddat.com there be sumtime there for you
i all ready have my R31 skyline diif shorten
soon to be mounting the suspension in to get it rolling,
i also using 120y front setup at the moment untill i sorted out the in changing to S13 fronts
im pretty sure you'll be told to do a search in wiki <-----
#4 Re: Datsun 1200 ute CA18DET mod - Help
-Hutch- Posted on: 2009/1/27 3:59
Thanks for that i will have a look in wiki and see what i can come up with.
As for the wind sheild i am sorry but i am only just starting (its my first project) so i am not sure where you could find one.
#5 Re: Datsun 1200 ute CA18DET mod - Help
perthute Posted on: 2009/1/27 4:06
maddat.com for pics n prices of parts
and faq on maddat site has a step by step guid
and datsun1200.com has a step by step guild in the wiki or faq you find it
most common diff r31 some use hilux but if yo want 5 stud go commonwhore diff
if silvia front brake swap is ezy then a r32/r33 should be ezy too has they are a bolt on mod for silvias and bam theres your 5 stud
#6 Re: Datsun 1200 ute CA18DET mod - Help
hotrocket Posted on: 2009/1/27 4:07
try ebay.....are you after windscreen or door shield??.....theres a fella selling them there from time to time i have one $145
#7 Re: Datsun 1200 ute CA18DET mod - Help
Posted on: 2009/1/27 4:08
if you ar doing s13 brake conversion to 120y struts, you could also probably mod s14 hubs or r33 skyline 5 stub set up.
Probably easier with 280zx sturts or r31 skyline ones though thn 120y ones due to stub axle design.
#8 Re: Datsun 1200 ute CA18DET mod - Help
dazza1200 Posted on: 2009/1/27 12:08
commo and falcon discs fit stanza struts
hilux diff is mega tuff (ford bolt pattern)
borg warners come in fords holdens and skylines so just pick an axle with your choice of bolt pattern
you need to make a decision early in the build as everything depends on everything else
i'm going 5 stud and i think 4 stud would have been easier
dazza
#9 Re: Datsun 1200 ute CA18DET mod - Help
Lachie Posted on: 2009/1/27 12:15
5 stud is good in that it gives you a whole lot of other choices in wheels, especially if you go 5x114.3.
#10 Re: Datsun 1200 ute CA18DET mod - Help
Montebello1200 Posted on: 2009/1/27 19:13
widnshield. were are u at? im very interested in that wind shield. mine has 2 cracks on the driver side.
