(1) 2 3 »
Intercooler size?
From Nyngan, nsw Australia
im in two minds in fitting a intercooler to my 1200,
however i want it to be behind the grille i dont want to remove nor cut front apron,
ive seen a few of you guys fronts give me sum ideas,
i will be using a S13 radiator and i also have removed the original radiator mounting for fitment to commondate the bigger one,
so what size coolers are you guys using
Posted on: 2009/1/27 5:54
living is good,.....
Re: Intercooler size?
From Snohomish, WA USA
I'm still trying to figure out how to put mine intercooler in. With my supercharger belt out in front of my engine belt, I had no room for my fan so I had to mount the electric fan out front of the radiator which took up all the space for my intercooler.
I have one out of a Mitsubishi Starion.
Intercooler
I'm probably just going to give up and not use one.
Posted on: 2009/1/27 6:08
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From gold coast QLD.
Has anyone thought of putting the standard intercooler under the front guard behind the headlight,there should be enough room,gotta be better than nothing
Posted on: 2009/1/27 7:11
Quite a regular
From Sydney
I dunno what size my intercooler is but it fits well behind the grill
cant get the pic to come up so check that out
Posted on: 2009/1/27 7:27
From Far, far away
At a pinch ours is 450x300x60, only done a trial fit with S13 rad but seems to fit with little mods.
Posted on: 2009/1/27 8:09
From cranbourne, vic
for "DAT12T"
click the [img] button then add the address (http:blahblah.jpg.. with NO!! [img.]..[/img.] in it.) into the box that pops up
im with bert, i cant see why you cant use a side mount IC like on a 180sx/s13, if you keep the ducting shield on you could easly scoop up the right amount of cold air.. they can cope on a sr20det with a t25 on 12-14psi..
Posted on: 2009/1/27 8:33
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
From Canberra
Here is a couple of pics of mine...
And with the grill on...
Posted on: 2009/1/27 8:53
thanks guys parden the punt im abit concern with the thicknest haha,
im sure length wont be a problem,....lol
i no by looking at i can make a couple changes to the rad support bracket just under the bonnet latch, but also i want to avoid cutting apron if possable.....i like the cooler of your there lachie
Posted on: 2009/1/27 9:58
From SE Melbourne
I've fitted 450 x 300 x 76 - I made some minor mod (had to open up the rad support) otherwise fit OK.
Posted on: 2009/1/28 3:15
Mildman, Datsunless
the width and length thats ok, its the thicknest,
when you say minor mods what exactly do ya mean?, apron, radaitor support....etc
pics
Posted on: 2009/1/28 3:24
(1) 2 3 »
