Re: Help with sr20 into 1200 coupe
From Rotorua nz
ok. do u have any pix of yours?
Posted on: 2009/1/30 1:43
From Christchurch
Nicks sr20 sedan
I poked mine back through the firewall a wee bit so the tunnel is a bit wider as a result, If you kept it forward enough it should hopefully only be about as big a tunnel as the ca ones I would guess. It probably wouldn't bother you having it forward a bit as by the sounds of it you want to have some fun on the quarter not ripping round the circuit
Posted on: 2009/1/30 4:54
From Christchurch
Nicks sr20 sedan
Posted on: 2009/1/30 4:55
From Rotorua nz
yeah i mean its basically going to be a street car that ill take to to the strip more for ####s and giggles than anything. im not out to break records hahahahaha.
Posted on: 2009/1/30 8:10
From Rotorua nz
hi nick,
just saw your pix. thats awesome man. keep up the good work.
Posted on: 2009/1/30 18:31
From Rotorua nz
bit of an update, got front struts sorted i found out that theres a certain 1200 with bigger struts bigger springs and 13" brakes so ive arranged a pair of those and also a brake booster etc in exchange for my a12 so that seems fair enough. so im slowly getting closer.
thats all for now.
Posted on: 2009/2/2 0:10
« 1 (2)
