Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: wrecking 1200 coupe. adelaide
nate
Posted on: 2009/1/28 10:35
mmmmm not sure. would have to be very similar. wouldn be as strong as a ute diff but fine for an a12
#22
77datoute
Posted on: 2009/1/28 10:40
thats all im running
but it takes a bit of a hammering!!
#23
DatsAndy
Posted on: 2009/1/28 10:41
Pre 74 ute had same as sedan didnt they ?
#24
ROConnor
Posted on: 2009/1/28 10:43
It may be benificial if your traveling long distance as it has a taller ratio
If you were to do it you would need to cut the shok/spring seats of the ute diff and weld them tothe coupe diff and relokate the break line spliter.
#25
WhiteSedan
Posted on: 2009/1/28 10:45
Just get a bluebird H165 centre and get new axle bearings...
As for the coupe rear end in your car, Shocks mount the same was as on a coupe, to the u-bolt plate, so technically you could bolt the whole coupe setup in, you'd need the tailshaft also. Oh yeah, the brake line splitter, but you could just cable tie that.
#26
nate
Posted on: 2009/1/28 10:48
well i have the tailshaft too if your interested. i
#27
77datoute
too much work atm with a broken hand!!!!
if i cant get a ute diff tho and you still have the parts ill let ya kno
#28
datsaute
Posted on: 2009/1/30 7:20
am after a floor rail and piece of floor for the drivers side - to suit a 75 ute would the floor rails be the same as the coupe.. if so how much $ i can cut out myself no worries
#29
nate
Posted on: 2009/1/30 7:37
i am guessing they are same. its a bit rusty in the drivers side foot area but your welcome to have a look. carton of beer and you can go crazy with a grinder on it.
#30
andy-roo
Posted on: 2009/1/30 7:48
Hey man r the indicators the same as the 1200 ute?
Cause I think mine on my ute r from a 1200 ute and I want new ones You can view topic.
