#1 Help! No fuel getting to carb!
Rainz Posted on: 2009/2/1 0:22
I have a 1200 wagon and fuel just seems to have stopped.
I pulled the fuel filter off and checked it for flow and it was OK. There is no petrol in the filter though.
What else can I check?
I have checked for spark and turned it over with some fuel tipped into the carby and it fires ok so thinking definatly a fuel problem
Any help would be nice :)
#2 Re: Help! No fuel getting to carb!
ROConnor Posted on: 2009/2/1 0:25
Last Time I had this problem I had rust in the tank, I had allready replaced all the lines, and anuly cleend the carbs and it still dident work. puld the tank out and shook it and it sounded like a maraka!
#3 Re: Help! No fuel getting to carb!
DatsAndy Posted on: 2009/2/1 0:27
Check for split in the lines around the fuel filter etc.Had a similar prob lately and found a split line on the fuel filter was sucking air.
#4 Re: Help! No fuel getting to carb!
Rainz Posted on: 2009/2/1 0:31
OK funnily enough after writing this i went out to check the filter again and noticed that there was some petrol in there this time...... So i poured some more petrol down the carby and wound it over till it fired up and now seems to be working fine again? Random
I think you may have it DatsAndy though as i noticed some fine cracks around the hoses.
I'll swap em out later.
Could be rust in the tank too as its been sitting around the last 10 years in a paddock.
Thanks for quick replies. Awesome!
#5 Re: Help! No fuel getting to carb!
ROConnor Posted on: 2009/2/1 0:35
This hapend to me when it was rust, would only block accasionly useualy under heavy load when the fule was flowing..
#6 Re: Help! No fuel getting to carb!
oldatsss Posted on: 2009/2/1 1:50
yea I had this, took ages to find changed everything dizzy to carbis, even put on a elec fuel pump still no joy, found it was paint flaks in the fuel line went through three filters and they just blocked , had to run a new line one.
