HELP!!! maddat diff question
From Sydney, Sutherland Shire
hey guys. i have fitted this maddat diff to my coupe. in the place of where the original diff had the bump stop rubbers, i now have flexible brake lines. to me it looks like it may hit and damage these brake lines if it bottoms out. this picture is with the diff floating under no load so it gets alot closer when on the ground. what are your thoughts?
Posted on: 2009/2/2 4:24
Re: maddat diff question
From perth airport
ill be fitting mine soon if i think its close ill unbolt the shocks and bounce the rear end to see if it does hit
Posted on: 2009/2/2 4:36
perth airport parking
Datsun 1200 ute A14
From Adelaide
yeh they do hit, i just grinded my bump stop thing flush with the chassis.. coz if u look where the bump stop hits its in the middle and doesnt use half of the flat steal anyway
Posted on: 2009/2/2 4:50
but then isnt the chassis still going to hit the brake line that runs along the diff?
Posted on: 2009/2/2 4:53
From Nyngan, nsw Australia
if you can....relocate the lines bracket witch are on top, move down the back abit
Posted on: 2009/2/2 5:23
living is good,.....
yeah i was kind of hoping i didnt have to make any changes because it was made by maddat and im not sure how they could get this so wrong. i have already had to re weld a bracket done by them in the wrong position. the whole point of buying the diff of them was so i didnt have to stuff around with things like this, it is supposed to be a direct swap.
Posted on: 2009/2/2 5:28
From Melbourne, Oz
Send them an sturn but reasonable Email, so as they can sort the problem for future customer's....
And maybe get yaself a voucher or sum sutch reperation?
Posted on: 2009/2/2 6:41
"I hav achieved wood"
did you tell them it was for a coupe body?
not a ute....
ive made my own skyline diff and removed everything and started puting the brake lines to top-side back of the off, if you no what i mean,
so it keeps them away from bupper stop anything like that, that mite get damaged
do you have another pic of the backend of the diff
Posted on: 2009/2/2 7:19
yeah i made sure they knew it was for a coupe but he did stuff up the brake line set up on it when i first got it, they said they did the steel brake line and junction as if it was for a ute.
Posted on: 2009/2/2 7:47
yes coupes & sedans there junchions are on the right side, utes are on the left, why i dont no.....
so why didnt they rectify the problem for you, shorly they help to fix it, there reputation steaks on it (medium rare to well done thanks)
Posted on: 2009/2/2 9:09
