Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Fuel pressure 4 a 32/36 webber
ratsun_a14
Posted on: 2009/2/6 10:44
just installed an electric fuel pump and i want to put a fuel regulator in aswell, just wondering what pressure it needs to be set at?
#2
Re: Fuel pressure 4 a 32/36 webber
steveo
Posted on: 2009/2/6 11:38
what engine is the webber on?
A series? L series?
#3
Posted on: 2009/2/6 12:00
why electric? stock mechanical is good enough for 32/36 on an a series? so about 4-6 psi max
#4
ratsun_a14
Posted on: 2009/2/6 13:06
sorry i should've mentiond its an a12. Mech pump is stuffed and i had a electric one lying around so i used it. What fuel regs are ppl using?
#5
aidaniel
Posted on: 2009/2/6 13:22
if your gonna buy a reg you might as well just buy a new mech pump ... the standard pump has good pressure and a really good flow rate
#6
beattie
Posted on: 2009/2/6 13:38
What pump are you using? Most standard replacement elec pumps will do the job. I had a 3psi facet(shit and noisey) and it worked fine. Now have a Pieburg i got for free and its great!
#7
Posted on: 2009/2/7 6:54
Weber 32/36 wants 2.5 to 3 lbs - same as a stock Datsun 1200 mechanical pump.
