#1 A series Engine to 610 ?
Sumith Posted on: 2009/2/12 6:16
Hi Guys
Is it possible to fit a A series engine to a Datsun 610 ?
Thanks
Regards
Sumith
#2 Re: A series Engine to 610 ?
WhiteSedan Posted on: 2009/2/12 6:21
Its possible but definitely a step backwards, why would you want to do that?
Sean
#3 Re: A series Engine to 610 ?
DatsAndy Posted on: 2009/2/12 6:21
Its possible but ummm Why would ya ?
Edit: Kind of double post there, You first Sean.
#4 Re: A series Engine to 610 ?
Sumith Posted on: 2009/2/12 6:24
Hi Guys
I like that 610 Face (Lights) and also it is much comfortable and luxury , to take good fuel consumption to fit a A series , A series are much better than L series in fuel isn't it ?
Thanks
Regards
Sumith
#5 Re: A series Engine to 610 ?
DatsAndy Posted on: 2009/2/12 6:31
To my way of thinking it will use more fuel than an L series. Its gotta work harder.
#6 Re: A series Engine to 610 ?
Sumith Posted on: 2009/2/12 6:41
Hi DatsAndy
Do you Mean , 610 Body is more Heavier , and A series may run Harder to tail that ?
What about A15 and L16 are those similer in Fuel , which will be better in fuel ?
Thanks
Regards
Sumith
#7 Re: A series Engine to 610 ?
WhiteSedan Posted on: 2009/2/12 6:45
L16 tuned correctly will offer good fuel economy, just run around on the primary ie. no more than 1/4 throttle.
#8 Re: A series Engine to 610 ?
DatsAndy Posted on: 2009/2/12 6:46
Yes it will work harder to tail it.Its not just the body that is heavier its everything in it to the suspension all the interior like dash etc. There is still quite a difference in performance between a stock A15 and L16 especially when you put either one in a 610.
#9 Re: A series Engine to 610 ?
Sumith Posted on: 2009/2/12 6:52
Hi White Sedan
will it(L16) do at least 10 Per Ltr ? and more on highway, have you heard more than that ?
Thanks
Regards
Sumith
#10 Re: A series Engine to 610 ?
ROConnor Posted on: 2009/2/12 7:02
Id emagine 10k's per Lt would be quite achievable with an L16
