Re: turbo setups
From northern 'burbs adelaide
yes but the setup in the pic wont work in a 1200 but the idea is right
Posted on: 2009/2/18 10:02
Re: turbo setups
From newcastle, NSW
thats what i said!
Use the search bar on the left hand side, there are so many members that have turboed their A-series, there is a stack of pics and threads explaining the process and stacks of advice!
Posted on: 2009/2/18 10:32
Re: turbo setups
Quite a regular
From Queanbeyan NSW
yea its for a 1200 sedan!!! its a daily driver, and i just want to experiment with it to she what power u can get out of it!!!! and allso to get the blow of valve noise.
voooooooooooooosh jokes.
that turbo setup looks like its all over the place!!!! and weren
Posted on: 2009/2/18 22:41
Re: turbo setups
Quite a regular
what happened to ur bored out L18 rally engine u bought?
Posted on: 2009/2/18 23:27
Re: turbo setups
From newcastle, NSW
Blow off valve can only be used on a blow through set up.
Here are pics of each set-up,
heres a pic of a supercharger set up that was for sale a couple months ago.
this is a pic of my blow though set-up on an a14
pic of topgear's blow through set up
All depends to preference, both turbochargers and superchargers have their own advantages and disadvantanges.
Superchargers have instant boost, turbochargers takes a bit to wind up, which to me is ideal for everyday driving because you drive normally without reaching boost, helps fuel economy.
Do you intend on doing the work for yourself? welding the maifolds etc?
Posted on: 2009/2/18 23:35
Re: turbo setups
Quite a regular
From Queanbeyan NSW
yea still got it, thats going into the 1600!!! how hot is it, borded out to 88.5 forged internals, the lot
i want the 1200 to look good and go hard! all my mates pay me out because they think datsuns are buckets of bolts, at are slow and crap, so im trying to prove a point with out doing engin conversions.
Posted on: 2009/2/18 23:36
Re: turbo setups
Quite a regular
From Queanbeyan NSW
well im not the best at welding and stuff so i was just hoping to buy a setup that should bolt stright on im lazzy
that supercharger that was for sale, do u no if it still is or did he sell it? do u know!!!!!
thanks
Posted on: 2009/2/18 23:42
Re: turbo setups
From newcastle, NSW
send Brad a PM and see if he has sold his set-up
Set-ups come up for sale from time to time, keep an eye on ebay and on here.
Posted on: 2009/2/19 0:29
Re: turbo setups
Quite a regular
From Queanbeyan NSW
thanks steveo.
i will keep my eye out, dont you worry.
thanks
Posted on: 2009/2/19 5:11
Re: turbo setups
You can definitely run multiple carbs and blowthrough. The lotus esprit used blowthrough dellortos (before GM bought out Lotus, and it got efi the following year). It's just double the cost to change a jet or other setting.
In practice, as long as the carb is big enough for the job, and the inlet manifold allows for good mixture distribution, a single carb will be just as good. there'd be less than 5% difference in the final result.
Of the two, turbos, since they take a split second to build up boost, actually are more gentle on the drivetrain. As long as you 'slip' the clutch a little on launch, and don't just jump off the clutch at high rpm, the box can take a lot of torque relative to how much shock loading it can take. Even with a stocko a12 if you jump off the clutch enough, you can break the stock gearbox or diff.
Having said that, if you can truly budget 3-4 grand, you should _very_ seriously consider the toyota t50 gearbox conversion and if you have the h145 diff, going to a h165 out of a ute, or a bw diff out of a later model datto.... I know it spoils the fun to buy that stuff first as you don't see any 'real' gain in performance from that much expense and work, but when you do get the boosted motor up and running, at least you won't have 5 minutes of fun, break the drivetrain and get discouraged.
Posted on: 2009/2/19 6:00
John McKenzie
« 1 2 (3)
