« 1 (2)
Re: question for the more knowledgeable 1k owners
I have heard the bluebird 411 backing plates can be used to upgrade to bluebird s3 rear drums for the front and back or a 1k and then the 260z alloy finned drums just slide on to replace the cast iron ones.
This is second hand information from Gordon Dobey whos done up many race 1k in his heyday so it might be worth looking into to save money by using cheap and common wrecked datsun/nissan parts.
Posted on: 2009/2/25 10:59
From pooraka,,adelaide
Hey man I think I might have sum part no's at home sumwhere I can go have a look and put em up if u like?
Last I checked rear are still in stock most places but front need to go to repco
I think back ones r about 20 bucks and front 25-30 mayb that was about 6 months ago
Posted on: 2009/2/25 11:08
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Darwin NT
yeh rightio post em up
Posted on: 2009/2/25 11:20
current project 4x4 patrol...
Ok I can't remember which ones are front or rear but
Genuine nissan- 41103-27700 I think there the ones u get from repco
independant brake supplies nsw IBS-JB2311 (these no's on there aswell 894275 5A I3)
Miyaco hydrolic brake service parts japan 64968070 that's front
Columbus wheel cylinder CJB2016 s/n25489
Hopefully they help man I got the boxes of 1000collector ages ago and he was tellin me they are all for 1000's
Posted on: 2009/2/25 12:44
vanette-a15 turb
260c- daily
1000 4dr- a15
garage 910
From Adelaide, Australia
i have had no probs at my local parts store for wheel cylinders. they are only about $18 each but they are the cheap ones or u can get urs re sleeved for about $50-60 each. i recon if u sleeved it they would last longer as they use a stainless steel sleeve
Posted on: 2009/2/26 0:21
From Perth WA
need to do the rubber seal as well, they are a problem blow out easily under hard braking. I paid about 40-50$ for a pair of wheel cyls from an independent brake place.
Posted on: 2009/2/26 0:27
From Alice Springs
so if you can change the 1000 drums to a 1200 drum, because 120y discs will fit the 1200, does that mean you can fit the 120y discs to the 1000? sounds silly, but just double checking.. also, the 1200 diff will fit the 1000? what about gearbox? sorry with the questions, thought it would be easier than opening another topic..
Posted on: 2009/2/27 1:25
Daily: 1979
From Darwin NT
yes you can adapt 120y brakes to the 1000 by using the 120y hub it bolts right on
the 56a should bolt in with no mods
1200 diff is the same unless its a late model ute diff
they can be adapted but you need flares or fwd offset wheels
im selling a ute diff thats been modded to suit 1000 so itll bolt right it and also has disc brakes
Posted on: 2009/2/27 3:20
From Alice Springs
thanks for your help, i actually have an early ('71) ute that i was trying to sell, but i will use it as a donor for motor and all running gear, plus the spare sets of 120Y discs i have. also, do you recommend going with 120Y electronic ignition instead of the a12 or a10?
Posted on: 2009/2/27 4:08
Daily: 1979
« 1 (2)
