« 1 (2)
#11 Re: CA18DET Throttle cable in 1200 coupe
PIGDOG Posted on: 2009/3/1 12:35
which end are you wanting to change?
putting an adjustable end on the stock cable is pretty easy as its just a matter of cutting the cable down and then the adjustable end slides on and you solder a new bar doover on the end
swapping the firewall end is a bit harder, just coz you have to find a new end as they are pressed onto the stock cable so arent reusable
#12 Re: CA18DET Throttle cable in 1200 coupe
Mildman Posted on: 2009/3/1 12:46
I see - I was thinking of changing the firewall end - maybe I can just get a 1200 cable and change the other end then....I'll take a pic of what I got tomorrow night (if I'm home)
#13 Re: CA18DET Throttle cable in 1200 coupe
PIGDOG Posted on: 2009/3/1 12:47
changing the engine end is the easier thing to do, makes it nice and easy to change back if need be
« 1 (2)
