Tuning
Quite a regular
From South Africa
Hi guys i was wondering how do you tune a a-14 without any special meters and goodies to be perfect any of you masters out there that can give me a tip or 2 because if you run on leaded fuel and your mixtures and timing and stuff is right the exhaust should burn white right?
Posted on: 2003/7/31 13:22
Old Datsuns never die they just go faster
Re: Tuning
From durban, south africa
hey bud,
what set up are you running?
carb, cam , exhuast???
you might need to change your main jets, go smaller, unless your carb is flooding.
anyway have fun
nicholas
south africa
Posted on: 2003/8/1 6:07
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
Re: Tuning
For a few tune-up tips on stocker motors, see the Tech Section article Tune-Up Information
If you have a modified engine and need to tune the carb, see section Tuning -- Making your Carb run right for YOUR engine in the article Which Carburetor?
Posted on: 2003/8/1 6:22
Re: Tuning
The spark plugs shouldn't be white, but should be tan/light gray.
White means too lean. Black means too rich. Oily black indicates engine rings are worn.
If you remove the cylinder heads, the piston tops and valves will show color as well.
Posted on: 2003/8/1 6:25
Re: Tuning
Quite a regular
From South Africa
Im not sure if its rings or valve stem seals because if i travel in town it burns black and if i put a bit of foot trough the gears i notice quite a bit of grey/black smoke but if i had it on the highway smaking it abit she burns grayish
Posted on: 2003/8/1 6:50
Re: Tuning
Oh, smoke. With good tune, and engine in good shape (good ring sealing), you should see nothing coming out of the exhaust pipe.
Unless its cold outside, or engine isn't warmed up. Then you might see water vapor (white smoke). This white smoke should disappear into the air quickly unless it is cold weather.
OK, so no smoke is good smoke. The black smoke out the tailpipe means unburned fuel. Choke might be stuck partway open, carb not jetted correct -- or very commonly, engine needs a basic tuneup (points, plugs and spark inspected).
Start by getting rid of the black smoke. Then see what is left.
For oil burning (bluish-white smoke that doesn't quickly dissapate into the air), a compression test is in order to see if the rings are sealing well.
Valve stem seals and/or worn valve guides will cause bluish-white (oil) smoke. But usually only for a few seconds after starting the engine.
Posted on: 2003/8/1 7:01
Re: Tuning
Quite a regular
From South Africa
Its time for its service anyway so ill try it and see what happens
Thanks
Posted on: 2003/8/1 8:21
