#1 C20 Vanette diff
R-fastmotorsport Posted on: 2009/3/2 10:45
As stated above - I have a C20 Vanette housing with mounts moved to suit 1200 coupe. I have used this set up in my racecar for the last 3 years with no dramas. Included are Bluebird disc brakes mounted to C20 (H165) axles with new bearings and seals (when converted 3 years ago). Sold without centre but can provide a 3.9:1 stanza centre if required. The housing is wide !!! 1290mm flange to flange - so check you can fit it. I ran flares with the car so I'm not sure if you can run it under a standard body. Price $300 - PM if interested.
Cheers
#2 Re: C20 Vanette diff
DatsAndy Posted on: 2009/3/2 10:50
mmm sounds good. How much wider than the original diff is it roughly ? Can you measure from Hub to Hub for me Please ?
#3 Re: C20 Vanette diff
mattblack Posted on: 2009/3/2 10:58
he has..... 1290mm.
#4 Re: C20 Vanette diff
DatsAndy Posted on: 2009/3/2 11:24
Ahh Thanks i overlooked that. Now to measure my standard coupe diff. No, No redbacks again please
#5 Re: C20 Vanette diff
PIGDOG Posted on: 2009/3/2 12:17
thats not a hub to hub measurement though, thats flange to flange
as a 1200 diff is 1310ish from drum to drum
#6 Re: C20 Vanette diff
DatsAndy Posted on: 2009/3/2 12:28
Flange meaning ?? The part the bearings sit in and the backing plates bolt to ? If so that would mean this diff is a lot wider again Hub to Hub.
#7 Re: C20 Vanette diff
datsunb120 Posted on: 2009/3/3 0:39
would it fit in a ute? i have flares so its not an issue
#8 Re: C20 Vanette diff
R-fastmotorsport Posted on: 2009/3/3 12:05
Could do - also depends on your wheel offset too.
Cheers
#9 Re: C20 Vanette diff
R-fastmotorsport Posted on: 2009/3/9 10:09
Bump it up
#10 Re: C20 Vanette diff
R-fastmotorsport Posted on: 2009/3/13 9:43
Last chance - be on Ebay from Sunday night.
Cheers
