Does anyone want something made?
From Ballarat Victoria
Im needing a few dollars to finish my coupe.
So im opening up my workshop for a few outside jobs.
- Aluminium welding and fabrication
- Stainless welding
- Bead blasting (huge cabinet)
- machine shop (lathe, milling machine etc)
All work of a profesional standard.
Give me a call if you have something in mind.
And if your a bit broke i`ll do a labour trade!
Cheers, Simon
0407 301 518
Im in Vic.
There is some pics of mine on here of the sort of work i do.
Posted on: 2009/3/2 23:12
VIC DYNO HIRE
Re: Does anyone want something made?
From Sydney
Can you make radiators?
Posted on: 2009/3/2 23:18
Hi Gav,
Yes. i`d either need the car or an acurate drawing to be able to quote and make it.
An auminium radiator takes about 6 hours to make. 6 x $30 is $180 plus the core and filler neck if reqired. it might take a little less time than that.
Anything in copper/brass can be made or modified also.
Email me the drawing if you want to go further.
Posted on: 2009/3/2 23:35
VIC DYNO HIRE
I'm interested. I have a shed the size of a f'in two-man igloo so I have nowhere to work. And all my gear is in the tropics.
Nothing flash, looking to get an intake manifold made up for quad carbies. Should be able to supply drawings.
Zap me an email at chrislyons@datec.net.pg for some prices on MS welding.
Manifold would be similar to lampy's, here it is.
Posted on: 2009/3/3 1:09
i'll have some die's in the next week or so that are a perfect match for the oval inlets on the flanges TnP made up last year.
my manifolds nearly welded up, i'll throw up some pics once its done. you can borrow or have a look at them if they're any use for you sikyne ? leigh knows a little of what i'm doing if you want to ask him, or send me a pm
cheers, adrian
Posted on: 2009/3/3 5:21
From Tamworth , NSW
ill second the quad carb manifolds.
also stainless scuff plates??
Posted on: 2009/3/3 7:19
From Coondle, WA Australia
I am like I mentioned before.
But the reality is that it will be awhile off, and considering that Frankthedolphinetrainer is looking at the exhaust side of things, ill grab one of them first, then send that to you to make sure it all fits together.
There are plenty of examples of Sikye's work on this site, and it looks the part. It would be worth every penny you throw his way.
Hmmm must restrain myself. Must build shed first, and get hoist up before Dundee.... must focus.....
Posted on: 2009/3/3 7:24
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
i'd be keen on scuff plates too! and some stainless covers for the strut tops
Posted on: 2009/3/3 10:48
If I supply you with an SU manifold, how much to weld up a plenum to it simular to what you did for Marks 180B?
Cheers. Don.
Posted on: 2009/3/3 11:04
i would be keen on some stainless scuff plates for a coupe aswell although i dont want the cut outs for the seat rails in my ones and also something to cover my strut top holes aswell
Posted on: 2009/3/3 11:17
