« 1 ... 6 7 8 (9) 10 11 12 13 »
Re: franks latest project
From newcastle, NSW
nice work, it will turn out schmik!
Posted on: 2009/1/17 11:20
From perth airport
hey man do you have any more pics of when you delipped the tray should be doing this to my ute on the weekend wanna see how much meat is left around the roof/pillars
looks like ya can get a job has a spray painter if you want , wat gun u useing ?
cheers
Posted on: 2009/1/18 21:11
perth airport parking
Datsun 1200 ute A14
From SYDNEY,NSW
looks so good with paint on!!! keep up the good work man..
Posted on: 2009/1/18 22:57
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
From Bathurst - NSW
Is it acrylic or 2 pack paint?
Posted on: 2009/1/21 9:22
From Brisvegas, oz
its 2 pac, i used a 1.4mm gravity fed star gun. dont really have any other pics of the lip but there isnt much meat to play with
Posted on: 2009/1/21 10:14
www.camerasplus.com.au
From Bathurst - NSW
Thanks, looks awesome.
Posted on: 2009/1/21 10:22
From Brisvegas, oz
heres whats been happening....
rear leafs reset to 3 inchs lower plus the diff has been replaced with a shortened r31 diff currently with a 3.9 open centre until i can find a cheap but good lsd. the diff also has 20mm lowering blocks fitted so i guess that good make approx 4 inchs lower than standard. it makes it look so much smaller than a normal ute. (small enough as is).
Posted on: 2009/3/3 5:33
From Nyngan, nsw Australia
what direction are you putting the calipers, have you had the cables made up yet....
how did ya go with the U bolts did you fined that they were abit small to fit over the housing
Posted on: 2009/3/3 5:55
living is good,.....
From Rosewood, QLD
man that would look low as with 4 inches of lowering and the sills on the tray removed.
Posted on: 2009/3/3 8:08
1971 B110 sedan project.
2012 Nissan Micra daily.
From pooraka,,adelaide
Did u come across any problems with shaving the lip off the tray?
Iv thought about doing it but not too sure if there is any tricks or anything like that
Do u have any pointers that would help doing it?
Cheers
Posted on: 2009/3/3 9:07
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
