Spark Plugs?? Help
Not too shy to talk
From Geraldton, WA
Hey guys,
I'm looking for what type of spark plugs I should use in my Datsun 1200, 1980 Ute, Australia. Everything is stock to my knowledge except for the extractors and the 5 speed gear box. Also what gap should I set it to?
Cheers.
Posted on: 2009/3/6 23:11
Re: Spark Plugs?? Help
bp5e or er if you have a resitor stle set up from memory, ngk brand.
gap i use is 0.8mm but manual specs are 0.8 to 1.0 from memory
check the book at the shop, im going from memory here at work on my break
Posted on: 2009/3/6 23:53
Not too shy to talk
From Geraldton, WA
Auto 1 has no idea really, they kinda just guess. Lol
Posted on: 2009/3/7 0:01
Try Bosch 09065
Spark plugs
NGK 7734 (BPR5ES)
Posted on: 2009/3/7 0:20
From Perth
If you use BP5EY you get a V groove electrode so a fatter spark
I used BP7ES in the hottie
I use 6's in the standard A15 streeter
Posted on: 2009/3/7 3:35
Not too shy to talk
From Geraldton, WA
So should i use BP5EY or BP5ES? lol. It's a daily driver, in mid western australia. B120.
Posted on: 2009/3/7 3:44
From Perth
Es or EY
The only difference is the V grooved electrode
SO either will do
ES is common as much anyone should have them
EY would be a better plug though
Posted on: 2009/3/7 7:25
