Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
model?
Davo1200
Posted on: 1999/12/5 10:33
What model did the A15 come in over there in USA?
Scott
#2
Re: US model?
ang94541
Posted on: 1999/12/6 8:12
According to my Chilton Repair manual, it was available in a 79-82
210,210MPG
#3
Re: US model?
sagemanone
Posted on: 1999/12/6 8:40
I am not sure if I have the model name right or not or year but I have seen the A 15 in a 310 or B 310 front wheel drive and the little mid engine model that
resembles the X 19. Steve
#4
Im new here+replies
ang94541
Posted on: 1999/12/6 8:43
I've signed up and have read about 100 previous massages...now i have a headache. Too much information.
Anyways, I'll reply to a few topics. Regarding an A12 with A13,A14,A15 heads, the oil supply to the rocker arms is a little different. I have a 5spd in my 1200 sedan from a 210. The trans bolts on to the engine(the A series bellhousings are the same) with only one problem the reverse light switch hits the body trans mount. Oh well, no reverse lights. The FS5W60A (current trans) has a 1-2,3-4,5-R shift pattern. The FS5W60L has the R-1,2-3,4-5 pattern. I have the gear ratios written somewhere. I remember that 3rd is closer to 2nd on the L and both have .846:1 5th. They both look and fit the same. The 3 previous 5spds,that i used, were wasted do to bearing failure. So when this one started buzzing, i had it rebuilt with new bearings and seals. It has lasted about a year so far.
#5
Re: 5 speed trannies
Rain_Master_Jr
Posted on: 1999/12/7 4:00
Ahhh, I wasn't aware that any of the 210 5 speeds had overdrive.. Definately something that I've been looking for.. thanks for
the info.. :)
#6
Davo1200
Posted on: 1999/12/7 10:45
From what i have gathered, A series 5 speed boxes never had overdrive. I got this info from the Nissan Motorsports Catalog which has all the performance stuff
in it for datsuns. There are 2 types of boxes but both have 1:1 5th gear. Maybe i have misread somthing? Scott
#7
ang94541
Posted on: 1999/12/8 6:56
You correctly read the Nissan Motorsports Catalog. I think these are competition or race parts and were not available as a stock option. At least not in the USA.
According to the Chilton Repair Manual for Datsun/Nissan 1200, B210, 210 and Sentra 1973-88 American and Canadian versions..."The 1977-78 B210 uses the model FS5W63A five speed transmission. The 1979 210 has a FS5W60L five speed transmission, while the 1980 and later use the FS5W60A five speed transmissions." I think I've used all three of these. They all look about the same. A Haynes Repair Manual shows the gear ratios for the 60L as .845 in 5th. And it has the R-1,2-3,4- 5 pattern. Anyways, they're out there somewhere. Happy Hunting.LOL.
#8
Davo1200
Posted on: 1999/12/8 8:35
I have a 5 speed box which has R-1, 2-3, 4-5 pattern. So your saying i 'could' have a overdrive box? I will have to pull it apart one day before i bolt
it to an engine. Scott
#9
bobs1200
Posted on: 1999/12/9 3:09
To check gear ratio without dissasembly place in 5th gear mark input and output shafts, turn input shaft one turn. If output shaft is at the same place as it started it is a 0ne
to one ratio. If it went past one turn, it is a overdrive 5th gear.
#10
Davo1200
Posted on: 1999/12/9 4:20
But that would be too easy!! I would have thought of that if i
actually used my brain. Scott You can view topic.
