« 1 (2)
Re: wanted twin port manifold
From Sydney
With a bit of home work you can build a ripper of an A-series based on std factory parts.
flat tops from a A10
sports cam from A12 GX
larger diameter valves from A15
double valve springs from GX spec head.
A14 crank in A12 block...
electronic distributor etc etc
the possibilities are very good with these little engines.
Do the rules state that the carb must be a asynchronous downdaught carb. If not I would be using the factory twin hitachi [SU type] carbs.
I would be very interested to read these rules.
benny
Posted on: 2009/3/11 4:32
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From gold coast QLD.
I assume we are talking speedway rules here.
I remember some time back someone else was asking similar questions.
If memory serves the speedway folk don't seem to recognise(or want to)any of the factory GX stuff....frustrating
Posted on: 2009/3/11 5:09
From Perth WA
is the KB 10 twin outlet exhaust manifold any good as an improvement to bigger a series, is it an improvement on an a14 standard manifold for example. I have a couple.
Posted on: 2009/3/11 5:39
From tassie
Would you be able to email me a photo of the manifold, if it has twin outlet exhaust and will a14 head it sounds like the one we're looking for
Posted on: 2009/3/11 6:17
From tassie
Mainland Australian's recently visited tassie with gx type manifold and kick our but
Posted on: 2009/3/11 6:20
The KB10 ones don't exhaust nearly as well as the GX ones.
It was on a stocker A10 with a touch more compression. It may be slightly beneficial on a stock larger A-series but I wouldn't consider it as a substitue for a GX manifold.
Posted on: 2009/3/11 6:25
From Perth WA
dad-sun,
like clyons said, its what i suspected, the KB10 twin outlet is a nice sounding rev-happy improvement on an A10 but wouldnt gain much on a bigger a series,
I can see u want your lad to be ultra competetive and good on u thats what i like to see, so search round a bit more for a gx item, get back to me if nothing turns up.
Posted on: 2009/3/12 1:32
« 1 (2)
