Browsing this Thread:
1 Anonymous Users
Re: an unspeakable crime! |
From pooraka,,adelaide
Quote: 1000Coupe wrote: the starlet motor is one of the few toyotas i like, its quite grunty for a 1.3, so a good choice to not need engineering and all. but how he has converted it to rwd i dont know.
The 4k come in the ke70 and they're rwd
Posted on: 2009/3/12 9:26
620 ute -sr20det full irs vanette-a15 turb 260c- daily 1000 4dr- a15 1000 4dr- project to be sr20
garage 910
there is no better pushrod in terms of reliability than a K series yota motor but it still should be put in a datsun thats like putting a NSU rotary into a Mazda.
Posted on: 2009/3/12 11:39
From 6065
I hope you guys dont crucify me if i finally finish (start) my 1000 chop top coupe with a supercharged chevy V6....
Posted on: 2009/3/12 13:04
From Perth WA
I think if u finish it u will find getting in and out a problem, lucky u r a shortass or u will never fit in it haha , im not very tall and ive got hardly enough headroom in my coupe.
Posted on: 2009/3/13 1:35
THe toyo 3k (esp early ones) are a strong motor. The blocks will take more boost than ought be possible (at least the ones I've played with - mid 20s boost and no intercooler, wandered into enough detonation to pop a head gasket and take a chunk of the head with it, but the block didn't incur any damage whatsoever). The 4ks generally have thinner bores and are less happy at higher rpm and or boost levels.
You would think (I know I certainly did which is why I played with toyotas at all some years ago) that being a 'slant' motor that the k series heads would flow more, since they are essentially a semi down draught head (if you look at port angle vs bore angle) - but in practice afaik the well ported big port (I suppose gx and then oval port a14/15 heads) datsun heads will outflow the bigport 3k heads (of the factory toyo heads, the best is the early 3k head, bigger ports and valves, and room for poirting - easily identifiable by a welsh plug on the back of the head instead of a bolt on plate and heater take off hose).
Another comparison that (imho) shows the datsun heads are better, is that I know of sc14 supercharged 5k (toyo 1.5) engines, that ran a 1:1 drive ratio and got over 15psi (close to 20 at >7000rpm) boost. The blokes here that have a14/15s that I can recall mentioned something more like 8-10psi from the same drive ratio - less boost means the head is flowing more, letting more into the cylinder, so less backs up and the inlet manifold pressure is lower.
the 4k toyos in the 'square' early 80s corollas (with 'hi-cam' badge on the boot) had dished pistons and a shallow chamber head, so using the early 3k head (flat pistons, bigger chamber) you end up with around 8:1 compression - hey presto cheap turbo friendly combo.
So ultimately the datto (imho) has more potential for power NA, which is a true test of power potential in the strictest sense). Having said that, the bloke has obviously put some serious time into the build, and deserves a lot of credit for that to say the least :) Still and all, it seems like a lot of trouble when the same result could be had from an engine that essentially is the same family as the original.
Posted on: 2009/3/13 3:19
John McKenzie
From Perth WA
I agree, i thought it was the starlet motor which is a little ripper, but if it is the old 'slant" 3k family, then yeh why bother, the datsun a series is so similar, slightly better, but at least its cheap to get a corolla 5speed box.
Posted on: 2009/3/13 4:32
Quote: K-DOGG wrote: I hope you guys dont crucify me if i finally finish (start) my 1000 chop top coupe with a supercharged chevy V6....
That would b sweet man make sure u post up pics
Posted on: 2009/3/13 4:35
garage 910
From Christchurch NZ
Quote: D wrote: there is no better pushrod in terms of reliability than a K series yota motor /quote]
I disagree. A sereis are no less eliable than the K engines. I've owned a 3K powered KE36, and a 4K powered ke70 wags. And I chose datsuns over them everytime. The rolla's feel like the handbrake is on compared to the datsuns.
Posted on: 2009/3/13 7:13
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
From northern 'burbs adelaide
now i must disagree when it come to the k series. i have owned a ke30 with a 3k then converted to 4k coz i blew up the 3k lol but for toughness the k and datsun a series would be pretty even but when it comes to power the datsun motor wins hands down ... i have no idea why but when you drive a 3k compared to an a12 you too would agree that the datsun motor is much better. but when it comes to buying parts the rolla wins because there no demand for them lol
Posted on: 2009/3/13 8:07
From Melbourne vic
speedway-A12 vs 3k.........A12 every time
Posted on: 2009/3/13 8:16
:Impressive, will it fly? :Yes, if i fold it here and here :Nice
