Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Fixing Voltage Meter
Sumith
Posted on: 2009/3/13 6:00
Hi Guys,
I have a voltage meter , i want to fix it and see it is working , can any one help me to fix it to the alternator through voltage regulator , and way to check whether it is working or not before fixing it Please Thanks Regards Sumith
#2
Re: Fixing Voltage Meter
Posted on: 2009/3/13 6:07
What kind of voltage meter? In general, they have two wires, one goes to earth, the other to "Hot".
#3
Sumith
Posted on: 2009/3/13 6:21
Hi ddgonzal
It is a round gauge(just like a wrist watch with red color indicator), that is all i know about it,i have seen those type of meter in racing cars , hot means (Power line-possitive) ? Thanks Regards Sumith
#4
Sumith
Posted on: 2009/3/13 6:28
Hi ddgonzal
and also there is same type of Oil Pressure indicator also next to that , want to fix that also Thanks Regards Sumith
#5
Re: Fixing Oil Presure Meter
Sumith
Posted on: 2009/3/16 8:42
Hi Guys,
Please let me know how the Oil Pressure Meter is connected , how will be the wiring connection if i connect oil pressure sensor and meter directly will it work or does it need another voltage line thanks Regards sumith
#6
Posted on: 2009/3/17 3:25
Unknown. Datsun B210 did not have an oil pressure gauge. Different kinds have different instructions.
#7
Sumith
Posted on: 2009/3/17 5:32
Hi ddgonzal
Look at this picture, http://datsun1200.com/modules/myalbum/photo.php?lid=19241 Here you see 2 small meters at the left , those are ampere meter and fuel pressure meter, i am referring to those, how to fix them Thanks Reagrds Sumith
#9
77datoute
Posted on: 2009/3/17 9:55
ive got both these gauges
the volt meter should have 1 wire as an earth and the other 1 will be positive. connect the positive to the on wire that runs to the ignition and the other to earth for a mechanical oil pressure u will need a small plastic line that runs from the guage to above the oil filter. i replaced the oil light sensor with the guage.
#10
Sumith
Posted on: 2009/3/17 10:39
hi 77datoute
Is Oil Pressure also need a earth and also the other connector to the Fuel sensor at the fuel filter or just a single line ? Thanks Regards Sumith You can view topic.
