120y v`s 1200 Crank (flywheel bolts)
From Ballarat Victoria
Can somebody confirm for me that some 1200 cranks have different (better) flywheel retaining bolts. It might be the thread pitch changes? Are they all 10mm?
Can anyone shed some light on this?
Thanks.
Posted on: 2009/3/17 22:03
VIC DYNO HIRE
Re: 120y v`s 1200 Crank (flywheel bolts)
From gold coast QLD.
Yes,10mm but a slightly differant thread pitch,someone a bit heavy handed could wind them in not knowing.
Posted on: 2009/3/17 22:07
Thanks,
Do you know which ones have the finer pitch? 10x1 im presuming?
I`ll go for the finer pitch unit.
Im about to spend a lot of money getting a crank ground and lightend for racing and i`d like to start from the best base.
Also, ARP make flywheel bolts in 10x1.
Posted on: 2009/3/17 22:29
VIC DYNO HIRE
For memory the early motors have the fine pitch
Posted on: 2009/3/18 1:45
From Freo
the early blocks are actualy IMPERIAL! then they changed to meteric threads... !!!
Posted on: 2009/3/18 1:52
A15 PSI Project Motor
'72 CB750k,
Dundee as usual is right:
crank now uses Metric M10 1.25 bolts to attach flywheel instead of english-system 3/8" x 24 UNF bolts
Posted on: 2009/3/18 2:06
So does late mean 120y? I need one. or is late ute the same? or anything after 1974?
Posted on: 2009/3/18 3:12
VIC DYNO HIRE
Anything starting in 1974. The A-series engine was redesigned, it has the dizzy under #3 spark plug. Earlier engines had dizzy under #1 spark plug.
Posted on: 2009/3/18 4:20
From Darwin NT
also sikyne if you happen to find a motor with m2 cast on the side it has one of those lighter cranks that the speedway boys are always after
Posted on: 2009/3/18 4:52
current project 4x4 patrol...
Everything i could posibly need to know about 1200 cranks. Im a happy man. Thanks all.
Posted on: 2009/3/18 4:56
VIC DYNO HIRE
