ca18det turbo manifold... what are you using?
just wondering what turbo manifold everyone is using on there ca18det in 1200's
can u fit a highmount in or a lowmount without any troubles with it fitting in the engine bay?
if you bought it off ebay can you post up the url for it..
cheers fellas
Posted on: 2009/3/21 0:25
Re: ca18det turbo manifold... what are you using?
From perth
stock
easy
you already have one (or i got a spare if you dont)
run all your stock stuff to start with. get the rest of the car up to scratch, THEN think about hotting it up
Posted on: 2009/3/21 2:11
yeh, i was just thinking its way easier to change stuff like that now before i get the motor in.
Posted on: 2009/3/21 6:15
From campbelltown (sydney) australia
dont buy an ebay stainless manifold, i did and they are crap... they look nice probly flow good but they cant take the heat mine has holes all through it which ive had to weld i now decided to make a steampipe one which im halfway through doing now ill post pics when its done...
Posted on: 2009/3/21 6:19
* caution, sunglasses must be worn to view my ca18det *
From Adelaide
all the stainless steel ones are just for show, there made on like a production line so how can they be good hey, dont do it..
for a decent manifold it has to be like 4mm thick so it can hold the heat,
steamweld one up or keep stock..
you only want it for looks, so why not just get it acid dipped clean and shizz..
Posted on: 2009/3/22 0:14
From Sydney, Australia
yep, the stainless ones were just a fashion craze.
Keep the stocker unless you desperately need to go high mount, or have plans to win autosalon. In which case you wouldn't use an Ebay one, and would need to find some $1000 Japanese one.
Posted on: 2009/3/22 0:27
if u now your way around tools and welders you can make a quality steel one for the same price of an ebay special i am just about finished mine, about 140 in materials and just my own time... most expensive part is the head flange
Posted on: 2009/3/22 0:33
From penrith,sydney,aus
my mate sells steampipe ones he makes on ebay there is an ad on here where he has them for sale too
i think his user name is sl33pe or sleepe
Posted on: 2009/3/22 1:55
2 door 1200 sedan project l20b stroker
From Sunnybank, Brisbane
if you're gunna do a good conversion, do it right the first time and spend a little extra so u know you wont have dramas down the track. 6boost manifolds are about the best around, get onto kyle tell him what you want and u'll get what you pay for.
Posted on: 2009/3/22 10:36
